derfdog15
Quote from: StealBlueSho on January 18, 2017, 09:51:15 AM
Nope not an oiled filter just a normal dry one...
I NEVER use an air compressor to dry out the filter... I have had several different cloth filters over the years and all say never to do that. It can loosen and damage the filter material... better to use fan to avoid filter material getting sucked up into the engine...
So did you use a product to clean it? Just curious, and I have never heard that about air compressor cleaning but good to know.
StealBlueSho
Quote from: derfdog15 on January 18, 2017, 09:59:02 AM
I have a bottle of K&N cleaner that I have been using for year, I did not use the oil obviously but the cleaner works well...
http://www.knfilters.com/mobile/mProduct.aspx?prod=99-5000
To be honest... it's just a mild soap.. you could use dawn that's been diluted with water...
A lot of guys just fill a bucket with soapy water and let the filter soak for awhile... shake it out a bit, rinse it in the sink until all the soap is washed out, then put it in front a fan for awhile... shake it out occasionally, turn it, set it back down...
The problem with forced air like a compressor is that it can damage the gauze creating air flow issues...and hot air from a hair dryer can potentially burn/shrink the gauze inside..
It's just a PIA...
StealBlueSho
When you don't have a funnel....
97novi2k
Finally got time to get some stuff done
Fuel pump recall
6 quarts or Pennzoil Ultra Platinum
New oil filter
Rotated tires
Car wash
Redline fuel system cleaner
Running like a champ
2014 Non-PP SHO Dark Side Metallic - LMS V10, PPE Downpipes, Windstorm CAI, 160 tstat, colder plugs
Quote from: StealBlueSho on January 18, 2017, 02:21:12 PM
Deer Park is a popular brand for the DIY'r it seems LOL
Quote from: 97novi2k on January 18, 2017, 06:45:33 PM
:thumb:
MiWiAu
Well, since temperatures were in the 50's yesterday here in Milwaukee, I decided I'd install my EBC Sport rotors and Yellowstuff pads.
Against my better judgement, I went in full bore with the intent of following the EBC instructions to reuse the pad slider/anti-rattle clips.
The clips on the first caliper/bracket I pulled (right rear) were super crusty, and I didn't feel all that comfortable cleaning and reusing the existing clips. No biggie (or so I thought). Turns out nobody in the Milwaukee area NAPA, Advance, AZ, O'Reilly stocked the hardware kits for the HD brakes. I called all of them and had them search inventory at all the area stores. I wound up ordering them on Amazon yesterday and now the truck sits on stands waiting for new clips to arrive some time tomorrow.
Should be pretty quick to finish up. All the pistons are compressed and ready to go as soon as the new hardware kits arrive.
Moral of the story: replace your brake hardware. Don't cheap out, even if the instructions say so. ;) Order hardware in advance or at least confirm availability in your area.
All that said, I am super excited to get my new brakes on. The rear rotors were in terrible shape. Looked like hot spots galore on both of the outboard surfaces, and both inboard surfaces only had only about 50% of disc area (in the center) that looked like normal wear patterns, which explains the terrible vibration I was getting with moderate to aggressive braking from interstate speeds. I'm pretty confident that my truck will now stop when I need it to. :)
2013 XSport
I am just glad the powerstop kits include the necessary hardware :)  Could you list the link for the HD hardware, just in case others are in a similar dilemma?  And pics of the old brakes and the XSport as it "stands" would be awesome!
MiWiAu
Quote from: SHOdded on January 22, 2017, 06:09:14 PM
You got it, boss! :)
Front Hardware (13.86" Rotors):
Raybestos H5865A Professional Grade Disc Brake Caliper Hardware Kit https://www.amazon.com/dp/B00D88PVJ6/ref=cm_sw_r_cp_api_zMuHyb0NME98D
Rear Hardware (13.58" Rotors):
Raybestos H5864A Professional Grade Disc Brake Caliper Hardware Kit https://www.amazon.com/dp/B00D88PVXC/ref=cm_sw_r_cp_api_CNuHybSFRDS90
Here is a picture of the old rear rotors (outboard side):
Old rear rotors (inboard side):
A sneak peak as it stands (new front GD Sport rotor):
2013 XSport
derfdog15
Mike,
I can not tell if your calipers are painted/coated or not. If they are not, now would be a good time to give them a nice coat of paint, since you already have them apart. I think it would definitely add to the wow factor with those EBC GD rotors!
MiWiAu
Quote from: derfdog15 on January 22, 2017, 07:32:53 PM
Mike,
Believe me, I thought about it. haha. Calipers are currently NOT painted; not quite warm enough this weekend, and I need to get it back on the road. I do have my eye on Craigslist for a free electric oven, so I can set up my own powder coating. Once I get something set up, I will order new calipers/brackets and powder coat them to minimize downtime. It will also give me a good excuse to flush out my current brake fluid and POSSIBLY install some stainless/braided brake lines... :)
With my next autocross coming up in about 3 weeks, I should have just enough time to bed in the pads/rotors just in case our next "winter" event ends up being warm and dry.
2013 XSport
MiWiAu
Done! GD rotors and Yellowstuff pads in all four corners!
Boy oh boy, does that break in coating sound terrible or what?! LOL
2013 XSport
AJP turbo
Let me know how those yellow stuff and GD rotors do...Those are the better EBC rotors. I had those and waited months for EBC to make the yellowstuff but I couldn't wait and got redstuff then I sold them all.
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
MiWiAu
Quote from: AJP turbo on January 23, 2017, 10:58:29 PM
Will do!
Yep, I went for their best rotor and most aggressive pads for my application. 'Merica! :)
I'll put together a review of them after everything is bedded in.
2013 XSport
BoostedSho2010
. Blacked out the center of the wheels, fender badges and trunk chrome strip.
