Disappointing Power
Started by POPSTAGE2, April 22, 2014, 09:23:16 AM
Quote from: Needmoreboost on May 07, 2014, 04:26:32 PM
I would not use t-bolts on plastic tubing unless you want cracks and boost leaks.  ;)
I agree!
This is the one exception. Plastic tubing connections nipples are engineered for the factory clamps.
Quote from: BiGMaC on May 07, 2014, 04:36:17 PM
I agree!
The HotPipe Kit several members have and use here come with T-bolt clamps for all connection points . No problems with there use and no one else had any  that I am aware of .
Quote from: SwampRat on May 07, 2014, 04:42:47 PM
I agree!
Likely not long enough... Like the article on the radiator connections says...
Quote from: BiGMaC on May 07, 2014, 05:15:15 PM
I agree!
Highly doubting this is an issue on the IC port connections and   I
TRUST Mike's judgement on the inclusion of T bolt clamps in the kit .
OEM clamps for the entire plumbing of OEM CAC system are screw type worm gear  , except BOV clamps  ... FYI
Quote from: SwampRat on May 07, 2014, 06:10:42 PM
I agree!
"Piping", of course, it technically not the radiator hose... subject of the article referenced... It is not a worm clamp.
Of course most of those CAC connections are  not the topic of my post, nor are they like the connections to thick rigid plastic nipples like the radiator has but, instead are thin semi-rigid plastic pipe to semi-rigid plastic hose or to rubber hose....
I trust Mike's product too... never even implied otherwise...You'll remember I helped in the fitment of this product (hotpipes) for the SHO
I think the hotpipe IC connections likely will be fine.....
However ONLY passage of time will tell with certainty... as continued EB owners cars age, regardless of our discussion or opinions.
RealityCheck
Quote from: Brucelinc on April 22, 2014, 09:32:30 AM
It will likely get better with more miles - with only 500 miles, everything is still pretty tight.  As for torque steer, I am surprised that you found the 2013 to have "scary" torque steer.  That makes me wonder if there was something wrong with it.  You shouldn't experience much torque steer.
My 2011 PP SHO had major torque steer stock.  It was even more noticeable after I installed an LMS 93 octane stage 4 tune.
My 2013 EB Flex had major torque steer stock. It's even more noticeable after I installed a 93 octane Unleashed tune.
My 2014 PP SHO had major torque steer stock.  It's even more noticeable after I installed a 93 octane Unleashed tune.
Several magazine tests have noted significant torque steer in AWD 3.5 Ecoboost vehicles.
Conclusion:
There are several possibilities. Folks who aren't experiencing torque steer are either:
1) Not fully utilizing the loud pedal, or
2) Don't know what torque steer is, or
3) Have serious engine problems, manifested by lack of power and minimal or non-existent torque steer
Try this. From a complete stop, take your hands off the steering wheel and stomp the gas pedal to the floor.  If your car doesn't immediately shoot off the side of the road, something is wrong with your engine.
2013 EB Flex Limited, 93 octane Unleashed tune
2014 PP SHO, 93 octane Unleashed tune, PPE catted downpipes, PPE noise maker eliminator, H&R springs
2011 PP SHO (sold), 93 octane LMS Stage 4+ tune, 13.1@106
JimiJak
Quote from: RealityCheck on May 07, 2014, 09:03:14 PM
Can't fault you for being direct! :D
2014 XSport Black Betty Build
RealityCheck  ...... No if ands or buts the transverse 3.5 EB has massive torque steer , especially when tuned .
Firm grip on wheel , eyes straight ahead and stomp it  .... Then SMILE !
Brucelinc
The OP said:
"when you nailed it at 55-60 mph the torque steer was incredible"
Different scenario than this:
"From a complete stop, take your hands off the steering wheel and stomp the gas pedal to the floor."
I guess everyone could have a different definition of "incredible."  I wouldn't call the torque steer at 55-60 under WOT "incredible" in an MKS or SHO.  Others have indicated that the Explorer Sport is worse in that regard.
By the way, we have a FWD Taurus SEL with the naturally aspirated 3.5 as well as the tuned MKS eco.  The Taurus does 0-60 in about 7 seconds while the MKS does it in 4.2.  Which one would you expect to have the most torque steer from a dig?
The torque steer SUCKS. It drives me nuts.
Brucelinc
I don't suppose a Prius torque steers as badly - might be a good option.
Lol! So, torque steer is the nature of the beast now, is it?
Funny...seems to be a non issue on real sporty cars.
black99lightning
Quote from: IHeartGroceries on May 08, 2014, 11:43:39 AM
I don't understand why you'd take your hand off the wheel on WOT acceleration, sounds dangerous to me.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
Don't know why it's news to everyone that torque steer is an undesirable side effect is a sports car.
Quote from: black99lightning on May 08, 2014, 12:02:03 PM
Aww come on and live I little. '
Also a fun past time is doing this at a rail road crossing and race to train..
Disclaimer bad idea.
