There's a ton to be learned from the Mazdaspeed enthusiast community. As much as many refuse to believe, the Mazda MZR is grandfather to Ford's EB series of engines.
I think many limitations of DI were fully realized by the MSF community before many others.
I've seen FoMoCoSHO and others mention the added capacity of some of the fueling components on 13+ EBs. If this is indeed factual, I don't think the limitations of 13+ OE components have been established. Tuning support would greatly assist in this, with 13+ 3.5l EBs.
There's not a lot of wiggle room in regards to pulse width with DI injectors, because of shortened engine cycle event timing windows, compared to PI.
So, it truly takes more volume. I think the chances of seeing plug and play, higher cc replacement injectors on the EB is like it was on the MZR - slim to none.
There's headway with meth injection, as we know, but short of actual replacement components, such as the HPFP and injectors, there's only so far you can go.
A permanent fixture of high HP Mazdaspeeds in a fifth port injector.
IIRC, 4DR has already dappled in this area.
What it takes is folks who are willing to push the envelope, in addition to solid tuning solutions and support.
