My first tune by Torrie
Started by boltmann, March 27, 2014, 01:11:27 AM
Quote from: Brucelinc on March 28, 2014, 10:26:27 AM
I highly suggest monitoring knock with Torque or better yet the Aeroforce gauges to make sure you're not in detonation all the time and not hearing it.
How can I learn more about this?  Should I be looking at "knock retard" or "learned Knock correction" on my aeroforce gauge?  I am not sure what it is telling me.
Knock Retard - if you're seeing negative numbers it means the ECU is seeing knock and pulling timing, this is a bad thing. If it's seeing it all the time then your tune needs to be adjusted to lessen the timing or boost or both.
68_GT
knock is caused by too much timing, or too much boost causing excessive heat right ? Can you start a datalog thread !? I just took the LMS tune for granted that it was a tamer therefore safe tune so I wouldn't have to worry about stuff like this, but I guess there's just too many variable and changing conditions to leave my trust completely to any canned tune right ? I mean this isn't just a need for LMS tunes, but for all no ?
southtxSHO
Seems like this thread took a different direction lol . Anyways good luck at the track . And vids vids vids if possible
Sent from my SM-N900T using Tapatalk
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
Yea!.... Good luck at the track this weekend!!!
Larrylu
Quote from: 4DRHTRD on March 28, 2014, 10:31:43 AM
This sounds like a gauge I'd like to add to my Torque display. I spent several trips through the Torque menu looking for "knock retard" or something similar to no avail. Is it there and if so what is the label?
You have to add it custom, there's information on how to do it, I'm headed out now but Ill try and find. You can search for knock pid and find it.
Larrylu
Quote from: 4DRHTRD on March 28, 2014, 02:11:02 PM
Thanks. I searched and was not successful but I'm notoriously bad with forum searches. If you clue me a bit more it would be appreciated. Looked through all the custom PID's in Torque thinking to add a KNOCK RETARD if I found one....no luck yet.
Needmoreboost
Quote from: Larrylu on March 28, 2014, 04:30:43 PM
Larry I do not know Torque, but hopefully someone else here will speak up.  :)
2014 Mustang GT/CS: white
Larry.... This might be the one:
http://www.ecoboostperformanceforum.com/index.php?topic=1448.msg16878#msg16878
Larrylu
Pay dirt!!  Now to input. Thanks for the assist
Quote from: Larrylu on March 28, 2014, 05:10:13 PM
Glad it helped...   :beer2:
Thanks for finding it, sorry busy with work and trying to figure out how to set up a huge wrestling tournament yet get a couple of passes in at Firebird tonight. :)
Quote from: 4DRHTRD on March 28, 2014, 05:22:05 PM
NP.... Hang in there on the tourney!, BTW, NOS and Meth Yet... Going for 9's?
Larrylu
Quote from: BiGMaC on March 28, 2014, 05:14:30 PM
So cool to be able to add new gauges. I added the values to create the PID and presto I've got a new gauge to keep an eye on. Thanks all and especially BiGMaC for finding the right thread. That was the toughest part of the job!
Wilson
Back on topic, lol. How did it go at the track last weekend?  Were you able to break into the 12's?
2013 SHO (non-PP) Ruby Red Tintcoat
Leading Edge Tuning 93 Tune | 3 Bar MAP | 170* Thermostat | Airaid Intake | PPE 2.5" Downpipes | Snow Stage 2 Meth Kit | H&R Lowering Springs | 22" Falken RT-7M wheels | 265/35/22 Falken Ziex TZ05 tires
