Lower Grille Removal
Started by Tyrann0saurusRX, March 16, 2014, 06:06:07 PM
Tyrann0saurusRX
Is there any way to remove the lower grill from my 2010 SHO without removing the bumper? I have reluctantly decided to add a front plate to my car (got a ticket) and I decided on a mount that will modify the lower grill rather than drill holes in the front of the bumper, but I need to remove the grill to mount the plate. Do I have to remove the bumper or is there some way to get this thing off? Any help is appreciated.
Quote from: Tyrann0saurusRX on March 16, 2014, 06:06:07 PM
I believe you do...
bpd1151 has posted a how to for just that: http://www.ecoboostperformanceforum.com/index.php?topic=521.msg3154#msg3154
Be carefull of the sensors behind the lateral ends and embedded in the visible "bumper"
First you will need to have the car raised up enough to get fully under the front of car .
All you need to do is remove the plastic lower service ( the one you take off for oil  changes  ) access cover .  Immediately in front there is a plastic piece that the lower air dam is attached to . It is held in place by a bunch of philips screws and push inserts and a bunch of 8mm bolts that screw into metal fastners , remove all of them including the two on the bottom of each wheel well.
The whole plastic piece with rubber air dam can then be removed .
Once it is out of the way you will have clear access to the lower grill .
If you are going to attach the plate bracket to the lower grill , I doubt you will need to remove it . It can be done but it is tight in there .
This how I put in my lower billet grill.
Yeah as swamprat state I doubt you would need to remove lower grill to do what your thinking. However you do need to remove lower grill the whole bumper will need to come off, the lower and upper grills don't come to easily and require a fair mount of effort to get them off.
Tyrann0saurusRX
#4
Thank you, and the plate isn't actually being mounted to the grill itself. I'm mounting one of these just inside the lower grill and I'm going to cut the grill slightly so that the plate can be slid into it.
Kinda like this video, except mine won't be powered.
Very cool part you found...
