Hi guys/gals,
This build will be full of "How to" info, somewhat in extra detail so everything is laid out so others can reproduce results like this or use them as a starting point. To audio install experts it will probably seem remedial, whereas for newbies or novices, I might be able to help somewhat. Just let me know if something needs tweaking to further explain or show something in particular to help
I've been working with a forum member (and now friend) at the Flex forum, on a build. It first started out with some product and idea discussions, planning, etc. Then the progression to designing a box (as I've detailed in this thread
http://www.ecoboostperformanceforum.com/index.php?topic=2172.0), and then came the discussion of who would install it, and when. That ended up being him and I over the course of last weekend. I designed and built the box (as the previous thread mentioned shows) early on, and prepped wiring etc. before his arrival, to save precious install time.
The equipment:
JBL MS8 processor
Vibe UK Slick Stereo 4 amp
Vibe UK Slick Bass 1 amp
Image Dynamics XS-57 5x7 components including the XS28 tweeter
Sundown SD-2 D2 10" subwoofers (pair)
PAC TR-4 remote-on adapter
Sound Deadener Showdown (SDS) deadening supplies
RAAM Audio deadening supplies
T-Spec main circuit breaker, and fused distribution block
1/0 and 4 gauge welding cable
lots of Techflex and heatshrink
This first section will consist of the how-to on the subwoofer box, which was made before the actual install started.
The build began with an idea of making a subwoofer that fits in the spare tire well, but out of wood instead of the typical fiberglass bottom. I have done many fiberglassing projects but the smell, mess, and cost make working with the stuff very difficult for me. The spare tire well is actually a geometric shape that is simple to build around. It took me 3 builds to realize that it is not just a wonky shape, but an actual "perfect" shape. I'll explain:
This is the spare tire well, from my 2010 Flex build but the shape is unchanged over the years. I would bet there are lots of current Ford vehicles with a shape like this.
The shape is easily reproducible, it turns out. The reproducibility means that building a box that fits inside of it, becomes something not only doable, but EASY. First, draw a square. In the case of the bottom of this well, I went with 26" square. Find center point by drawing an X from corner to corner of the square. Draw a half circle on one half of the square, so that radius is 13". For the other half of the square, draw two X's side by side, so these would then be 1/4 of the square, each (x2.) These get 1/4 circles from the X's drawn, and that turns out to be 6.5" radius. That's the whole box shape, drawn in seconds.
My reason for explaining this is so you can build one without much effort, because you don't even need to measure your trunk now. By the way, if you make the square just a little bit smaller (let's say 25"), it would probably fit a little better (lower) in the tire well than the one I did, but would be a smaller box overall. If you have lots of wood to work with, I suppose you could layer one over the other (say a 25" square and a 27" square), and cut out the shape to make a hollow step. I didn't have spare boards to cut, so I kept it simple, but you can see the potential here to make this work however you wish.
This is the shape I ended up with in my design. By segmenting the shape into straight lines (6 for the half circle and 3 for the 1/4 circles, each),
The angles for these cuts turns out to be very predictable. Since each 1/4 circle needs 90 degrees to make the angle, we simply divide that by 3 (per 1/4 circle) and we get 30 degrees. That turns out to be 15 degrees per side of wood, and that's what the saw is set to. For straight sections, they received a 7.5 degree cut (1/2 of 15 degrees.)
There's some metal that serves as the spare wheel mount in the center of the well, so you'll see that the box I made has some cutouts to handle that. All I did there was measure distances and cut bit by bit into the box, until it fit into place easily. I do believe my saw was off about a degree, because in the end my cuts were not "perfect", but still workable. Here's some in-progress pics.
So after the test fit was successful, I glued and air-nailed the box together, one section at a time. Then test-fit again to be sure. You can see here that the cutout has been covered with a layer of wood. Not shown but part of this design, I had to rout a roundover into the box's bottom, which let the box sit in the well just a bit better. The box's sides have a height of 4 7/16". This could be a variable number that could go higher for deeper subs (at the expense of not having the seats fold flat), or lower with more shallow subs (and the seats could then lock flat.)
This is a sneak peek test-fit of the Sundown sub in its new home. The top of the box is not actually installed here, just three brad nails to hold it in position so I can cut my circles. I use a Jasper circle jig btw.
These are a few test-fit runs, to find out the final height of the installed system. We are using bar grilles on the subs to give them the clearance they need while still protecting them from the seats. This will be augmented with an additional cover as well. As you can see, the seats will still flip and fold almost flat, but not quite. This was considered an acceptable thing by the recipient of this box, but if
Now the box top is glued and nailed together, and set into place with clamps overnight. I've also sprayed the interior with a high quality rubberized sound deadener/sealant I found from Rustoleum.
The next day, I started on the box's cosmetics. I chose a vinyl that matches the upper section of the interior in a Flex, followed with a durable black "trunk liner" grade of carpet on half of it. The separation of the two will become apparent in a bit. Also note the banana plug terminal installed. In case you are new to installing, buy air tools and the appropriate air compressor and accessories. I use an inexpensive but pretty well made air nailer/stapler from Walmart of all things. Staples are great for low-depth things like this vinyl, and nails are fantastic for box building in general, but staples can work well too (with glue.) Once I finally made the jump from screws and glue to air (and glue), my box building speed tripled. I can discuss this in more detail in another post if anybody is on the fence about going with air tools.
This is a close-up of the sub we're using. Note the side vents, especially. This sub has no back pole vent, and that means the sub can sit in a box that is no deeper than the sub is itself. This is a big advantage with a build like the one we're doing here. Not many subs have this feature, and most you must leave some space behind to let them breathe properly. This is a dual voice coil sub, 2 ohms each on this model.
I built a simple spacer board and wrapped it in vinyl as well, then test-installed the box. Turns out, it is very (very) heavy, and it barely fits. The shape ends up being a bit of contortion to get in, and out of the trunk. I wouldn't build a box any taller, or longer than the one I'm sharing with you here, because it most likely will NOT go in the car once you've built it.
These test fits are in my own Flex, and you'll notice that my back panel is cut to allow the box to fit. This is pretty much the only permanent "mod" you must make to your car, for this type of box. This panel isn't nearly as expensive as others on the car, should you wish to return the vehicle completely back to stock.
This is a further test-fit of the intended top cover board. Note the green LED which may or may not make it in the final rendition, but was fun to play with. I'd like to give you more details as to how I made this top cover, but really it was a lot of trial and error. Once I had the subs in the box, and the box in my Flex (as a test), I found myself with a problem. That problem was, how do I make the top cover fit right? So I drew up a template and cut a shape which worked, but then the issue of cutting out the subwoofer hole came up. I ended up making tiny cuts first, and I measured where I was vs. where I wanted to be, and inched myself through with cut after cut, until the board plopped into position perfectly. I actually made one board and completely mis-cut first, then did it all over again (correctly this time), with a new board. Sometimes you just have to learn the hard way.
After I got my shape, beveled/smoothed the edges all around and sanded it, then wrapped it with some plush carpet to get it looking nice.
You can probably see why I made 1/2 the box top with black carpet now
This is how the shape of the board fits against the back panel, excuse the saw dust.
The board actually sits right in line with the grille, so objects can be placed on the carpet and grille as one. I'll probably make a final cover board for both, later.
Continued with more (much more) later on...
