I'm slowly compiling all I need to install my devils own meth injection, and I am basically down to nozzle placement. I have seen where others have drilled and glued/epoxied the nozzle in the plastic elbow right before the throttle body, however I'm not to keen on that idea.
The two options I have are:
1.Machining a custom nozzle holder that replaces the factory noise maker. Pro's easy to return to stock, con's time consuming to machine and nozzle will be sitting at least 1" back from the intake flow (puddling).
2. Buying a devils own intake tap (
http://www.alcohol-injection.com/en/water-injection-parts/271-nozzle-mounting-adapter.html)and placing it in the rubber hose before the plastic elbow that goes into the throttle body. Pros cheap, easy, in the intake flow, con's will have a hole in my rubber hose.
I'm leaning towards #2. What's your thoughts?
John
