Ecoboost PCV issues
Started by Tuner Boost, February 23, 2014, 05:25:16 PM
ShoBoat
2012 Pearl White CTS-V Stock
That is flipping insane. It so odd what can happen to a motor and yet it will keep running and other time small stuff goes and causes a completely blown motor.
68_GT
So if I run a rx catch can I will have to drain out 12 ounces of gunk out of it every 150 miles and if I don't I'm running the risk of gumming up the inside of my engine, hydrolocking it, or thinning out my oil to the point of a catastrophic failure !!!!!!!!? seriously !? ugh !!!!
I don't think the situation is THAT bad :) but regular maintenance per your driving style is a MUST.  I always equate frequent performance driving to a severe duty schedule.
68_GT
did you see how much crap poured out of that can after 140 miles lol ! Seems like all of these engines with out a catch can would be destroyed all the time.
True.  Maybe boost multiplies the problem.  Maybe we should instead be looking at a PCV atomization-direct injection system to burn all this stuff in the combustion chamber!  I mean if Mercedes can have 2 spark plugs per cylinder, why can't we have 2 injectors, right?
68_GT
great just another thing to worry about ha ha !
ShoBoat
Let's keep in mind that the turbo seals on the EBs and every other turbo engine out there are known for leaking. At least a little bit, that may not all be from the PVC system. It seems a bit much just from the PVC, if that was the case these engines would not run for long at all lol.
Tuner Boost
So far, the cars do not seem to have anywhere near the amount caught as the trucks, and I suspect the intercooler has something to do with that as the truck gets a ton of air flow past and seems larger capacity, and that video is in below zero weather and anything below 45* F results in much more water as part of the mix. The shop truck we track we are still getting app 4-5 oz's a 1000 mile week out of, but were here in FL and temps are mild. In the 40 degree weeks we had in Jan/Feb we got twice the amount per drain, so until we have more results from the cars (have over 250 on ecoboost trucks, but only a handfull on the cars) we cant judge the severity of  or amount on average caught. You want NO oil ingestion on a DI engine, but I am suspecting the cars will have far less of the water, and there are stories from techs at Ford dealers seeing trucks hydrolock, but I have yet to hear of a car doing it (unless a low mount CAI scooped up water in a deep puddle).
Tuner Boost
Quote from: ShoBoat on April 10, 2014, 06:55:19 PM
Some times we see small seepage from turbo seals, but the 250 plus EB's we have the RX system on the past 3 months have zero oil now (or water) in their CAC's (the ones checking) and the amount they keep catching is substantial. 4-8 oz's a 1000 miles or so. Also, oil leaking from a turbo seal wont be routed through the can to catch so it would be both in the CA and as when a seal fails, it is generally hot and cold sides due to shaft play, exhaust smoke is a sure give away, but not always.
Quote from: Tuner Boost on April 10, 2014, 09:32:07 PM
...and don't confuse the sooty exhaust tips that all ourn SHOs have with smoking exhaust....
ShoBoat
In the vw diesels they put drain plugs in them lol. There is a vid on YouTube of a guy draining 1/2 a quart of oil from the cac from leaky turbo seals and that is normal.
Quote from: BiGMaC on April 10, 2014, 10:11:24 PM
Not mine...
Quote from: FoMoCoSHO on April 10, 2014, 11:03:39 PM
Not mine...
you alchy!    LOL
That's another thing to look out for.  Does the catch can system cut back/eliminate the chimney-smoked/coal-mined look?
