Is the Livernois tune as good as people say?
Started by Jetmech92, February 16, 2014, 10:36:36 AM
Jetmech92
All,
If you read my other posts, you know I'm a new SHO owner.  I want to add a tune and it seems the Livernois tune is the one everyone suggest.  Is it as good a people say?  Also, do I have to change or gap the plugs and replace the thermostat?
Thanks,
Chuck
Livernois  or Unleased by Torrie are popular Tuners with members .
One step colder iridium plugs gaped at .030 and 170 t-stat recommended.
corrected above gap from 35
black99lightning
Quote from: Jetmech92 on February 16, 2014, 10:36:36 AM
All,
Thanks,
Chuck
it's a good tune.  It's the one I'm currently using.  Torrie at unleashed also has very good tunes.  I don't think you could go wrong with either tuner.  It's the best bang for the buck and the basis for other mods, as the tunes can be revised.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
Nothing else that you can do to your car that will give you so much satisfaction.
Jetmech92
Seems like I need to go ahead and pull the trigger on the tune.  The car drives so good now I cant imagine more power and better shifts. I'll definitely get the plugs and thermostat since that seems to be highly recommended by everyone as well.
65460
Quote from: SwampRat on February 16, 2014, 10:49:06 AM
One step colder iridium plugs gaped at 35 and 170 t-stat recommended.
I thought the recommended gap was .030 ?
2014 Black SHO
Livernois 93 Tune
I've had a Livernois tune since my car had 6300 miles on it and I won't change for the world, I love it and the service I got from Livernois, however, I would also purchase and trust a tune from Unleashed Tuning any time, Torrie has a great record with his tunes and has very good service!
Quote from: 65460 on February 16, 2014, 12:04:12 PM
I believe LMS does recommend the spark plug gap to be .030 and definitely a heat range cooler.  It is to prevent misfires and spark blowout at increased boost.  Also helps the ECM prevent detonation.  OEM is .035
dalum
2013 Non-PP SHO
black99lightning
Quote from: Jetmech92 on February 16, 2014, 11:00:57 AM
The shifting is the better part of the tunes.  I put mine back to stock the other day, and couldn't believe how slow and dragging the factory shifting is.
Jetmech92
Well I pulled the trigger and got the LMS tuner, plugs and thermostat.  Hoping for the best.
A big step forward in SHOvolution!  Gonna be tearing up the streets in no time flat :D
roushed
How are the tunes on the sports when it gets very cold out from what I remember ken have a lot of issues my biggest fear would be rough idle and surging
Sent from my SPH-L710 using Tapatalk
