My custom tune does have a little trans work.. Firmer, and supposed to drop a gear when shifted into M. I haven't really tested it thoroughly. I know that over 50 when I shift to m, it drops a gear and if you coast, it will drop another. This is meant, I guess to help drop speed after the 1/4. I really need to get the Torque going and do some real testing. BTW, it does have added boost below 2K and above 5K. Dan was able to make these tweaks from when I had a dyno out there last summer. After I get these other projects done, I'll be going to the 3 Bar tune.
