Just a little small advice,just have the proper o ring ready with the stat and make sure the car is cold,let the car sit overnight,so when you remove those 2 8mm bolts you will have the least amount of fluid coming out,and also remove the reservoir cap,release any pressure build up,i lost about 6 ounces,
