You guys are correct, thank you for the replay. I was wondering about this because I wanted to get wider tires/wheels and I wanted to see if any space can be gained as the the strut is the only thing in the way. Helped a lot. I don't want to run wheel spacers, so what would be the best offset wheels for 20x9 to fit a 275 tires? Are there any other modifications required, one again, the wheel spacers are out of question. And, all this with the car lowered with H&R springs. Is it possible, or 265 would be a better option, but tire options are limited.
