Aftermarket Paddle shifters
Started by Shonuff1140, January 20, 2014, 03:02:15 AM
Shonuff1140
I have seen that Hurst makes some awesome looking aftermarket paddle shifters to replace the Camaro's plastic fantastic ones. Does anyone know if there are any aftermarket shift paddles made out of nice stuff like billet aluminum, unstead of the crap we have?
RisskyBusiness
I was similarly wondering if it would be possible to swap out my 2010's for some of the 2013 paddles. Would it be possible to program or wire it to have the right be up-shift and the left to downshift? Sorry chad if I'm stealing your post, I can create a new one if you want.
2017 Explorer Sport - Stock, for now...
vernonator
Lets just turn this into a paddle shift thread, I know may of us using tunes do NOT use them due to the shift lag. Is there anyway to "tune" that out? Not sure if it is something that is adjustable or simply a fact of the implementation.
I tried to use it last night and the lag made me rethink as I reeved a bit higher than I really wanted to :)
2012 Tuxedo Black SHO w/PP. Livernois Stage 4+, PPE Catless DP's, EBC Stage 4 Front/Rear Brakes
2015 Tuxedo Black Explorer Sport 401A, no mods....YET :)
RisskyBusiness
Quote from: vernonator on January 28, 2014, 02:37:14 PM
I've had that same issue with mine
Same here.  That's one reason I don't use them.  The other is that it is a little difficult to shift when you are turning the wheel.
Quote from: DJE624 on January 28, 2014, 06:18:38 PM
Me either.. I just point my right toe in the direction I want to go with downward pressure.... More and more I am coming to believe this car may be smarter than I am!
navbtcret
I like playing with mine once in a while, I do not find the lag time being very bad though. My car shifts crisply with them. I usally use them when I am passing someone on a two lane road, I down shift 2-3 gears as I am stomping it to the floor.
2013 SHO Non PP, LMS 93 Performance v8, 3 Bar MAP, 170 Stat, MDesign CAI, Hot Pipes with TiAL BOV, PPE Catted Downpipes
Quote from: navbtcret on January 28, 2014, 08:39:06 PM
ZOOOooommm!!!  :smiley-faces-75:  :burnout:
Shonuff1140
I know they don't have the most function, but if I was pulling back on aluminum, it would trick my brain into feeling it was a far more expensive vehicle.
Quote from: chad1140 on January 29, 2014, 04:58:09 AM
Nobody Drag racing use them but not because they are slow but because you can't shift faster than the auto even if you had a stick. I Auto-Cross my car and you never move your hands from 9&3 on the wheel(unless the back end is going the wrong way) so paddle are just fine. The paddle shift fast as you can auto-xing and better than automatic because you see the turns coming. The paddle put you in the right gear in the right place doing the turns. They work AWESOME IN THE SNOW(Down shifting to stop, holding a gear and not up shifting) JUST GREAT!!!!! The Aluminum replacement would look great.
2011 SHO VS SCCA AUTOCROSS
dmharvey79
Our cars have shift paddles? (-;
I liked the gated shifter my 2011Fusion Sport had , Manual mode activated by button on T Handle shifter.
Shonuff1140
Quote from: dmharvey79 on January 29, 2014, 09:12:34 AM
I was mentioning replacing the plastic ones with aluminum paddles. Like Hurst does for Camaro.
REDSHOCGO
To be honest I don't use them either to much lag
2010 Red Candy Sho 402a option non/pp w/unleashed tune,3 bar map, k & N CAI, Corsa catback exhaust, tints 35% front 20% back vta conversion,plastidipped front grill (matteblack), Curva Concept C7 wheels w/20" toyo proxes +4 and Sony Xperia z running torque pro
2011 Sonata 2.0T Limited tinted
2007 Pontiac G6 GTP cpe w/crab intake,Led sequential taillights, custom exhaust(now gone)
