Mulling over rim choices
Started by Frozen Taurus, January 14, 2014, 08:47:27 PM
MeanKS
any recommendations for acceptable weight ranges for a 20 in wheel for our cars...
also, does anyone know the 'standard' weight for the 20 in SHO and MKS factory wheels?
MKS-EB...
Quote from: DRII on January 21, 2014, 01:24:10 AM
As far as the flower wheel's weight: You might go to the ford parts site. if it doesn't say then there will be a shipping weight.
Quote from: Frozen Taurus on January 19, 2014, 06:50:49 PM
I am not giving up on this, I just don't see how a 22x9 265 tire fits but no way in Hell a 20x10 275 tire will. I will run a bit of negative camber up front if I have to to get the rim to tuck into the fender.
I will measure this spring and see what I am working with before I order for sure
Thanks to those have helped out
Here are my 275x40x20 on 20x8.5 they fit GREAT!!!!
Frozen Taurus
That's what I can't wrap my mind around ....a 275 tire is fine in the wheel well on a 8.5 inch rim ....but as soon as you add 3/4 of an inch on each side of the rim there is no way it can fit  :evilmad:
Talk to Joe (?) at Detroit Wheel & Tire.  I am sure he can supply you with accurate weight information on any of these OEM wheels.  Website is at https://detroitwheelandtire.com/contact and EBay store is http://stores.ebay.com/Detroit-Wheel-and-Tire.
Frozen Taurus
Quote from: shoman04 on January 21, 2014, 05:21:40 AM
What offset did you go with Shoman?
Lanson
#66
The lighter the better!
I would be very happy with 25-28 lb wheels on a car like that.  30 lbs would probably be my ceiling.
BTW, if you do a wheel like a 2 or 3 piece or a forged barrel, the math is not quite the same.  There's a part that nobody measures (except perhaps race scientists) where even with a heavy center section, the barrel is very light.  Thus the rotational intertia of the wheel is less.  Same with rotary forged wheels like the TSW Nurburgring and Interlagos.
Here's a rule of thumb I was taught, and it has never left me:
Less weight = good
Less unsprung weight = better
Less rotational mass = even better
Less unsprung weight with less rotational mass = do it already
Here's some light reading, taken from a decidedly heavier reading article
http://www.camaroz28.com/forums/lt1-based-engine-tech-9/sprung-weight-vs-unsprung-wieght-vs-rotational-mass-63883/
I don't have an EB but I am an avid modder and happy to help the community and learn/grow.  Pretty good with audio and wheels, my build and discussion threads are here in the forum.  2013 Flex AWD N/A
Audio:  Dayton Reference home speakers in front stage, incl. 2-way passive custom pillars 2.5" mid, 3/4" tweet, 2-way passive custom center channel 5" mid, 3/4" tweet, 8" midbass in doors, Vibe UK amps, JBL MS8 processor, Optima Yellow-top custom-wired, Exile subs in spare tire well
Mods: H&R, K&N, 22x9 & 22x10 3 piece forged wheels 265/35-22 Toyos, SCTX4 w/ 91 oct. Torrie tune
Lanson
Quote from: Frozen Taurus on January 21, 2014, 08:40:47 AM
IDK what to tell you.  The wheel contacted the strut during fitment check.  Wheels aren't 10" wide when they say 10" wide.  They are 11".  It is an extra 1/2" per side for a bead to mount the tire.  A 275 wide tire isn't 275mm wide.  It is as wide as mounted on the wheel.
BTW Shoman should be running a +34 offset there, if memory serves.
Lanson
#68
Frozen just roll 20x9 on a 275/40-20 all around if you want.  That'll work perfectly with the right offset.  Immediately a wheel that comes to mind is the XXR 968 that is on its way here.
http://www.nlmotoring.com/XXR-968-Wheels-20x9-Flat-Black-p/96809652f.htm
No idea if it will fit over the brakes or not, but otherwise should be perfect.  A +35 on a 20x9 is a sweet fit, and meets your goal standard back and front.  Oh yeah you can look at the XXR 526 as well.  Again don't know if it will fit the caliper, but otherwise should be good.
Frozen Taurus
Frozen Taurus
#70
Well after lots of thought I have decided to go with a staggered fitment of 20x10 rear with 275/40 and 20x8.5 front with 255/45 in the TSW Panorama
Weight of 20x8.5 is 23 lbs
weight of 20x10 is 26 lbs
Way to go man! I'm sure you'll love them.
Quote from: Frozen Taurus on January 21, 2014, 09:17:53 AM
Bnoon (a Flex guy) sold them to me. I had to go find this thread to know what the offset is.
General Information / New wheels
« on: April 12, 2013, 12:32:53 PM »
I know wheels would normally be an aesthetic upgrade, but these are only 25.2 pounds each, so they're a performance upgrade as well!  :biggrin: They are 20x8.5 36 offset black Bullitt Motorsport replicas from American Muscle. They are so much lighter than the regulat Bullitt wheels even, let alone lighter than the stock wheels. I want to see.if 2754020 will fit, but that will have to wait since my current tires were brand new when I got this rig in January. Pics once I get them on!
Woah Mama!... another inch of tread width without spacers!
Quote from: Frozen Taurus on January 21, 2014, 08:00:26 PM
IS YOU FINAL CIRCOMFERENCE THE SAME?!?! If they are not the same you will have problem with the AWD going in to limp home mod at the track.
http://www.discounttiredirect.com/direct/infoTireMath.do
