I have the pump, tanks, and most wiring ran. Few questions on the wiring since the instructions received are for a generic kit install. So the red/white/bare wire from the pump go to the PAC, the green tied into to Green/Brown map signal wire goes to the PAC, the PAC controller, and of course the LEDs.
The PAC itself has a fused power and ground. BUT I also received a relay and with an inline fused power connection. Do I even use this? I figured I would just run the fused power connection from the PAC to an ignition on source. I had though this relay might be for the pump but the instructions have the pump going directly to the PAC.
Also, which fuse are 2013+ guys tapping into. I'm having trouble finding an ignition on only source. Fuse 46 doesn't exist and I went to fuses working the same items that 46 did in 2010-12 and I'm getting +12 with accessory.
Clarifications would help, looked over the how to's of course but they left out a lot of the details.
Thanks
Sent from my iPhone using
Tapatalk
