Originally posted by glock-comaChanged RDU fluid today
04-14-2013, 08:40 PM
Just thought I would post some pics
Here are some DIY 2"x12" car ramps I made.
Found these over @ evolutionm forum
http://forums.evolutionm.net/evo-x-g...bout-40-a.html
I used a Hydro-Turf oil extractor and a quart fluid pump both found on amazon.
http://www.amazon.com/Hydro-Turf-Oil...sim_sbs_auto_1
Pic of RDU fill plug....I used a 3/8 drive ratchet to remove it. The hole is pretty shallow, so the ratchet will not go completely in. Anyone know why that exhaust hangar is there?
There is not a bracket on the pipe below it
Drain plug before cleaning, and after. Some metal filings, but nothing to worry about
I couldn't completely warm up the fluid for easier extraction, I didn't want to deal with a hot exhaust while under the car. It was moving very slowly through the tube.
I got out as much as I could, about 32 ounces by weight.
The fluid was pretty nasty. It was the consistency of syrup, maybe a little thicker
Here is a side by side of old fomoco "lifetime" fluid and new redline 75-w90
Wasn't that hard of a job, the pump just took awhile because of the thickness of the fluid.
While I was waiting, I also changed the spark plugs to the new updated part number CYFS-12Y-3. Probably going to do the PTU fluid next week.
12/4/2015: Thanks for the re-linked images, glock! Much appreciated
