PP Owners: Removing Air Compressor Foam Insert
Started by SRT82ECOBOOST, December 17, 2013, 01:38:34 PM
SRT82ECOBOOST
As I get closer to my audio build, I have determined that I want to mount my equipment in the area of the trunk that is currently reserved for the foam insert that holds the air compressor. I have had a couple tugs at the foam and appears to be just glued in place. Has anyone tried and successfully removed that foam?
FracaSHO
Mine came right out. Maybe it wasn't suppose to but I had no problems. Do you plan on keeping it? I prematurely tossed mine and decided I wanted it after all. But it's not cheap from Ford. Would you be willing to sell it?
Brad
2010 Tuxedo Black SHO w/ PP
SRT82ECOBOOST
I will probably pull it out when I sell the car. Thanks for the information about the removal.
