Quote from: 68_GT on December 01, 2013, 10:42:35 PM
that also makes me wonder if our cars would benefit from a larger intercooler then ?
I've had over 30 turbocharged cars and EVERY one that I upgraded the IC on made noticeably more power. A few years back, I had a DOHC 2.2 Dodge Rampage that was running almost perfectly and consistantly for months. The day before heading to a race in Vegas, the IC size was doubled, it ran so much stronger I couldn't belive it
Turns out that it moved so much more air, it leaned out the AFR's and holed a piston in Vegas
The first thing I noticed peeking thru the grill when I got my Sport is how SMALL the stock IC is AND that it's not a very efficient design. It has relativley few long tubes that run the length of the core, this style leads to high backpressure and higher temps than an IC that has multiple shorter tubes. I have one left over from a previous build that I think will fit after modifying the outlet to 3" and moving it to the other end of the endtank. I'm gonna build the downpipes first, have my exhaust guy build an entirely new system(I'm still collecting parts, I have almost everything but the first muffler I ordred isn't gonna work) Install the LMS tune and then install this IC. I'll have some feedback after that. Here's the IC.
