Ecoboost Vendor Section
Ecoboost Vendors
Livernois Motorsports and Engineering
MyCalibr8or tuner update application
Started by BigPelo, November 21, 2013, 09:50:59 AM
BigPelo
Sr. Member
I'll SHO you
The link Rick LeBlanc sent me last year to install the tuner update application isn't working anymore. I need to install it on another PC. Can someone post it here or via PM? (For 2013 SHO if that matters)
Thank you and have a nice day!
Week-end family transporter: 2013 SHO tuxedo black, performance package, unleashed custom 94 octane tune, K&N Typhoon intake, 170F thermostat, 3 bar MAP sensor, SP534 spark plugs, 5000K HID Morimoto mini D2S projectors retrofit, tinted windows, Full LED lighting in and out, Eibach springs
Daily beater: 2002 WRX wagon swap JDM STi v7 20G'd
Guest
Re: MyCalibr8or tuner update application
November 21, 2013, 12:00:06 PM
I don't have the link anymore but if you call them, I would think they'd send it to you.
EcoBrick Bob
November 21, 2013, 12:54:52 PM
Wouldn't it be on My Cal Mfg website?
Naples, FL & Clear Lake, IA
slurppie
Full Member
Force Fed
November 21, 2013, 01:52:56 PM
Is this what you need?
1. Download the following 2 files from the following links. Be sure to download both files to SAME folder on the PC.
a. Download file 1 at
http://www.webservice99.com/downloads/tunerupdateapplication/V2/current/setup.exe
b. Download file 2 at
http://www.webservice99.com/downloads/tunerupdateapplication/V2/current/UpdateInstallV2.msi
c. Note the location on the PC as to where these files are being saved.
2. Go to the location on the PC where the 2 files were downloaded to.
3. The following two files should be present (setup.exe and UpdateInstallV2.msi).
4. Double-click (run) file setup.exe. This will start the installer that installs the Tuner Update Software.
5. Follow the on screen prompts as usual to installupdate the application.
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
Forum Supporters
SHOGAZM
#4
November 21, 2013, 03:38:40 PM
Thanks slurppie for providing this information.
Much appreciated!
Ecoboost Vendors
