Started by ecoboostsho, November 08, 2013, 09:47:16 AM
Quote from: ecoboostsho on August 08, 2014, 11:29:51 AMOkay I think I've figured it out. I did quite a bit of logging on the way to work with FORSCAN. First I agree with ShoBoat...I typically only see maybe a blip or 2 of knock at part throttle but it does seem temperature dependent...with the outside temps in the 70s this morning and running at highway speeds I honestly had a hard time generating any knock. If I let the motor heat soak I can see 2 or 3 degrees.As for the equation it wasn't really far off at least compared to FORSCAN (sorry for anyone hoping it was if you've got a +7 reading). After numerous logs and serial captures the PID does use both the A and B parameters in the equation. The B is the 1/4 degree part...just took some thinking. I still need to go out and verify this but I believe this is close...The sign may be off though but either way it would only be off up to a 1/2 degree...Signed(A/2)+(B/512)This would result in readings from -3.75 to +7.25 degrees of timing added or subtracted accordingly. The bad news in this is if you are getting 7 degree of knock I do believe the "reading" is accurate...it doesn't mean it's actual knock though...just that the knock sensor is picking up something it thinks is knock. However if you go back to stock and the knock goes away I believe it was sensing real knock as opposed to the throttle body shutting etc...just my thoughts.
Quote from: ShoBoat on August 08, 2014, 01:50:23 PMI made a slight change to the equation (Singed(A)/2)+(B/512) this seemed to work.
Quote from: FoMoCoSHO on August 08, 2014, 02:34:58 PMOddly, since I flashed my car last night my gauge now shows -5.This has me scratching my head.
Quote from: ecoboostsho on August 08, 2014, 02:37:27 PMQuote from: FoMoCoSHO on August 08, 2014, 02:34:58 PMOddly, since I flashed my car last night my gauge now shows -5.This has me scratching my head.Flashed to stock? Very well could be...no one knows how much timing the car actually adds under light throttle?Sent from my XT1060 using Tapatalk
Quote from: ecoboostsho on August 08, 2014, 02:37:27 PMQuote from: FoMoCoSHO on August 08, 2014, 02:34:58 PMOddly, since I flashed my car last night my gauge now shows -5.This has me scratching my head.Flashed to stock? Very well could be...no one knows how much timing the car actually adds under light throttlSent from my XT1060 using Tapatalk
