Torque Knock PID - may have some progress...
Started by ecoboostsho, November 08, 2013, 09:47:16 AM
Larrylu
#150
Finding that the equation is/was accurate is not a disappointment for me even though I was one of the ones to register a 7 positive. It just makes me extremely grateful to have been lucky enough to have a KR gauge in service that did give me a heads up. I was much closer to the edge than I care to think about.  I could have been blissfully ignorant.  I have not updated to the new equation yet as my car is at the dealers for some tranny TSB issues but having flashed back to stock in advance of this dealer visit I can say that I now have generated a max of positive 1 reading so far on the stock tune.  Thank again ecoboostsho for the life saving gauge and once again for vetting the equation when the serious readings surfaced! Very appreciative indeed!
ShoBoat
Quote from: ecoboostsho on August 08, 2014, 11:29:51 AM
Okay I think I've figured it out.   I did quite a bit of logging on the way to work with FORSCAN.  First I agree with ShoBoat...I typically only see maybe a blip or 2 of knock at part throttle but it does seem temperature dependent...with the outside temps in the 70s this morning and running at highway speeds I honestly had a hard time generating any knock.  If I let the motor heat soak I can see 2 or 3 degrees.
As for the equation it wasn't really far off at least compared to FORSCAN (sorry for anyone hoping it was if you've got a +7 reading).  After numerous logs and serial captures the PID does use both the A and B parameters in the equation.  The B is the 1/4 degree part...just took some thinking.
I still need to go out and verify this but I believe this is close...The sign may be off though but either way it would only be off up to a 1/2 degree...
Signed(A/2)+(B/512)
This would result in readings from -3.75 to +7.25 degrees of timing added or subtracted accordingly.  The bad news in this is if you are getting 7 degree of knock I do believe the "reading" is accurate...it doesn't mean it's actual knock though...just that the knock sensor is picking up something it thinks is knock.  However if you go back to stock and the knock goes away I believe it was sensing real knock as opposed to the throttle body shutting etc...just my thoughts.
I just tried this equation, I got a reading of 127 KR. Lol
2012 Pearl White CTS-V Stock
ecoboostsho
Say what?? ;) I tried it all the way home and got pretty normal results...are you sure that you don't have a space between the signed and (A)??
ShoBoat
I made a slight change to the equation (Singed(A)/2)+(B/512) this seemed to work.
Quick trip to store netted results in same ranges but in tenths....saw -.2,-.5,-.8,-1.2,-1.5,-1.7,-1.8,-2.2. Might be more but those I noticed for sure.
ShoBoat
That did the trick, on mine. Now reading in .2 increments. -4 to +1.2 on my drive.
ecoboostsho
Quote from: ShoBoat on August 08, 2014, 01:50:23 PM
My bad...you are correct.  I had the same thing in Torque...just typo'd the equation here (well actually I went from memory and you can see how well that worked out.)
I have seen it add timing on light throttle in quarter degree increments...-.25, -.5,-.75...all the way to -4.0.  I have seen 2 or 3 degrees of positive knock when heat soaked as indicated before.  Interestingly it actually reads in finer increments than .25...occasionally I see .18 or .36 etc...seems to respond faster but that's probably just because the B variable is giving us finer resolution.  I will keep testing but it seems promising.
Oddly, since I flashed my car last night my gauge now shows -5.
This has me scratching my head.
ecoboostsho
Also just to clarify Torque will round this off for you depending on how many decimal places you have. I did notice the gauge which shows max and mins is fixed to one decimal place so it will appear in tenths. That is more than sufficient for our purposes though.
ecoboostsho
Quote from: FoMoCoSHO on August 08, 2014, 02:34:58 PM
Flashed to stock? Very well could be...no one knows how much timing the car actually adds under light throttle?
ecoboostsho
Quote from: ecoboostsho on August 08, 2014, 02:37:27 PM
Or do you mean its -5 all the time??
Damn, quote fail....
Stock to tuned..
ecoboostsho
Got it. Well there's nothing in n the equation or PID that would indicate -5 isn't normal so you've got me. It is probably something that can be changed via the tune...
I did also notice a +3 after a wot pedal lift this time to fall in line with the others.
