The self-tuning thread
Started by EcoPowerParts, October 15, 2013, 11:50:46 PM
I'm going to start this thread as I'm starting to tune my own car and wanted to share what I'm doing and seeing if anybody else can add as well.
We started playing with the various tables for a couple of hours tonight, attempting to modify torque maxes. We haven't found it yet but we'll keep messing with it, it will probably take a few days. I wish there was a canned tune we could use as a base and go from there as there's SO MANY tables!!!
I'll report back as I know more!
BTW, my whole issues with map sensor slope/intercept we were trying and the car not starting was actually we had changed the traction control setting to 0 (from 35) and the car was pissed and wouldn't start. We started over with a stock tune and only added the 3 bar and then luckily the car started so we could begin the tuning fun.
05yellowgt
I'm assuming the only option for us mere mortals to tune with is SCT PRP?  I reached out to a buddy of mine that just started working for HPTuners.  They are currently working hard on getting full support for 05-14 Mustangs, but may be interested in working on the Ecoboost platforms at a later date.  If they do, I want to work with him to get the software working.
2010 Ford Flex Limited w/Ecoboost- SOLD
2013 F150 FX4 Supercrew 6.5ft bed Ecoboost w/3.55
Yes, you'll have to buy the Full Racer Package, somebody on the forum did it but then they disappeared and I didn't hear from them again.
05yellowgt
I've been a loyal SCT user for years and even worked part time for a buddy at his shop and have tuned many vehicles, including my own using it.  I am going to hold out to see what HPTuners comes out with as their pricing and flexibility when it comes to being able to tune multiple vehicles is very appealing.
05yellowgt
Oh, I wanted to ask if you know what level of access you have with the PRP package?  I know that with the 05+ mustangs, unless you had an in with SCT or went through their training, you couldn't access some of the more advanced tables (drive by wire throttle programming).  I wonder if this is the case with the Ecoboost ECUs.
EcoBrick Bob
Wouldn't it be nice if HP tuners would work with us... Know they have so far resisted.  I too am interested as I have 2 G8's and have 2 son's with 3 LS engined cars plus another one on the way.   Perhaps once they do the Mustangs, they will look at EB platform(s) due to the large volume of F-150's.
Naples, FL & Clear Lake, IA
05yellowgt
That is my hope and with the Ecoboost coming to the Mustang in 2015, it may help open the door for the rest of us as far as HPTuners is concerned.
TouchOfEvil
This is my first Ford and as such i have no exp tuning them. I come from a long line of Chevy and hptuners. Which gets used often, lol.
2014 XSport
metroplex
I know this thread is old, but HPTuners finally added most of the tables for the 2013-up SHO and 2011-2014 F-150's around mid July 2016. My 2014 SHO is now tuned using HPTuners and pulls 16+ psi across redline w/ 87 octane, stock airbox with dirty paper filter, and there aren't any fueling errors. The maximum inferred air massflow is about 50.1 lb/min and using Garrett's formula for estimating horsepower based on massflow, that's roughly 474 hp.
I haven't looked at SCT for the SHO, but I heard there's more than 1 driver demand table. HPTuners is working to add the driver demand table (for terrain??) which is what Sport mode uses. Without changing that table, shifting into Sport mode causes the car to go back to stock boost levels.
Other than that, HPT looks like it is good to go for 2013-up SHO's. They were still working on 2010-2012 SHOs, and 2015-up F-150/Mustangs. They support all of these vehicles, but there are missing tables.
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
metroplex
#10
I like the graph features on HPTuners. In any case, the ECU figures out the WGDC, throttle opening, etc... and as you can see it was holding 16+ psi at 6000 RPM right before the upshift. I'm logging a lot of PIDs, so I noticed that there's a delay in some of the graphs with the actual data.
While experimenting, I found that I could force the throttle open (with the custom WOT start/stop values) but this just causes the WGDC to drop big time, and the boost will start at say 16-18 psi and then drops to 10-12 psi at the revlimiter.
How well does it run at 0.85 lambda? I was experimenting with this as well and couldn't find much data from anyone other than dyno sheets for F-150's w/ the 3.5 EB and they seemed to be running 0.85 lambda with 87 and 93 octane. I tried 0.76 lambda once and ran into fueling issues, but 0.79 was fine and at the verge of running below 1200 psi. 0.82 gives me solid fuel pressure, and I'm thinking 0.85 might be better and I run that lambda with the GM LNF (GTDI at 22+ psi boost).
12.4 @ 110.9 mph
Quote from: metroplex on July 29, 2016, 03:34:07 PM
16-17 PSI and I think 22-23 degrees available timing w/o knock so far.
Tons of rail pressure
You can hold just about any boost you want.
Forcing WOP does not cause the wastegate duty cycle to drop AT ALL!...Your decline in boost is purely from your desired TIP being reduced...You need to find out why that is happening.
Quote from: metroplex on July 29, 2016, 03:15:02 PM
Metro share some of the hardships that the HP tuning community is facing also...There seem to be a lot of confused people struggling based on what I read
I would not say HP has added MOST of the tables for the SHO. From the screenshots of the software it looks like they are missing hundreds of tables, scalars and functions...The screen menus look so basic and lacking...There are only a few tabs with drop downs...You can literally get lost in the tables in SCT.
So I wouldn't say it's a go lol..They are leaps behind it looks...This is also according to other tuners I know.
Holding 16 psi at redline is not any accomplishment, it's really easy to do if you want and know how.
There are multiple driver demand tables....The terrain table is NOT for sport mode...The Terrain table is the exact same as the regular driver demand table....You are missing other tables with HP
metroplex
#14
Hey chief, so what's the table for sport mode?
Eric from HPT said that the terrain table is used when switching to sport mode. Talking about a factory stock setup, it makes sense that it would be the same as stock. Why would you get more boost or different boost in sport mode on a factory tune? For my situation, the boost levels are custom in Drive mode but switch to the stock 8-11 psi in Sport mode.
From your dyno post, it seemed like it took you 2 years to get through the SCT tuning process and SCT was missing values early on. So what are some of these important parameters that are missing in HP Tuners? Are you using the latest version? They only added more SHO tables within the past week or so.
As for forcing the throttle open, I don't think it is necessary. With the tables that are currently available in HPTuners (3.20.50), forcing the throttle open causes the WGDC and Desired TIP to drop, resulting in starting at around 18 psi then dropping to 12 psi. I even heard some aftermarket tunes are this way as well but this will only net about 42-43 lb/min inferred air massflow.
When I let the ECU do its thing, the WGDC and desired TIP pretty much stay the same. The only time the throttle closes is during the shifts but it doesn't really affect MAP boost. I looked at your dyno thread and the log you had showed massive TIP spikes during the shifts, and I believe you've always recommended changing the WOT settings.
12.4 @ 110.9 mph
