- Full Member
- Newb
- Logged
Quote from: ThePresidential on May 29, 2022, 04:52:48 AM
As my 2013 lincoln mks is my daily driver, reliability of the engine comes first. Im looking at getting a water meth injection setup, is there a kit for the 3.5L ecoboost that allows you to inject only water, just like bmw has done to one of their stock vehicles?
I definitely understand reliability over power. My SHO is my DD and only enclosed vehicle. Is there a reason you don't want to use some meth? The easiest method would be -20 blue washer fluid. Readily available, ~30/70 meth/water ratio. Despite the reliability goal, my desire is to go with a system similar to Ecoboost_xsport that has fail-safes in place. I would shy away from straight water unless it were in very small amounts. It will provide some cleaning and cooling but, with no fuel offset, I would feel like it is a very fine line between benefit and problem.
Lucy Ford 2015 Ruby Red Tinted Clearcoat Metallic, GearHead AO Performance Tuned - SCT X4, GearHead Intercooler, 3-Bar MAP, EPP Hot Pipes (Plum Crazy), EPP Dual Intake (Plum Crazy), AD Mounts, MSD Coils, JLT Oil Separator, 160 Thermostat, Ortiz Performance Battery Hold Down (Plum Crazy), Hellcat LPFP, 255/45R20 DSW06 Plus, Sync3 Conversion, CYANLabs Syn3, FMods, Jail Broke APIM, Infinity Kappa Speakers, Speaker Baffles, Whelen POV Response Package - (Inner Edge FST, Inner Edge RST, Sidekick, Tracer, LINV2, IONV3, HHS 200W, Howler 200W), Z-Flash, Full LED Swap, Drive Bright DRL Kit, Drive Bright Puddle Light Kit, Ford Sunroof Visor, Window Chrome Delete, OSRAM XENARC Night Breaker Laser, FORScan, OBDLink, Ford Cargo Organizer
