September 24, 2023, 07:40:27 PM
Author Topic:  RDU puking oil again  (Read 3915 times)
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« on: December 20, 2021, 05:22:12 PM »
About 6 months ago i had the same problem and removed the pan and cleaned everything up and refilled with new fluid. Its not over filled. So now it pushing fluid out from the top again and I have no idea why? Any thoughts out there? Car has 110k and is a 2012 MKS
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
Re: RDU puking oil again
« Reply #1 on: January 11, 2022, 04:09:14 PM »
It still is coming out top and leaking on the garage floor at night. The car is driven by my wife and never raced, Yes we are old and it never sees long trips and we just drive it around town at low speeds. I have talked to some repair shops and they are talking about replacing the entire RUD or rear diff. It make no noise and has no other issues. The car runs perfect. I have been repairing my own cars for about 45 years and have never ran into a problem like this?
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Eastern Pa.......
  • Thank You
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 37
« Reply #2 on: January 12, 2022, 10:17:10 AM »
When you say leaking or pushing out the top. How much ? I know it shouldnt be doing it at all.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13071
  • -Received: 4265
  • Liked:
  • Likes Given: 186
« Reply #3 on: January 13, 2022, 05:43:27 AM »
how much fluid are you adding, and what fluid exactly are you using in the RDU?
Offline TopherSho
  • Elite Member
  • Eugene Oregon
  • Thank You
  • -Given: 504
  • -Received: 415
  • 1st boosted rig!
  • Liked:
  • Likes Given: 5
« Reply #4 on: January 13, 2022, 09:54:14 AM »
Just out of curiosity .. is it cloudy? (contaminated?)
Best 0-60 public road 4.35s
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« Reply #5 on: January 21, 2022, 02:01:04 PM »
It drops about 4 drops per night on the floor.
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« Reply #6 on: January 21, 2022, 02:04:44 PM »
Not adding any since the cleanout with rear cover removal. Motorcraft 80w-90 rear axle lubricant.
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« Reply #7 on: January 21, 2022, 02:06:12 PM »
No its clear but is coming out the top of the breather.
Offline jman
  • Full Member
  • Ontario
  • Thank You
  • -Given: 28
  • -Received: 32
  • Ecobooster
  • Liked:
  • Likes Given: 12
« Reply #8 on: January 21, 2022, 03:39:43 PM »
I had a bad breather on a Sienna AWD, dealer wanted to replace axle seals for more than $1k. I'm thinking that if your breather is not opening at the right internal pressure (caused by heat and expansion), it might be spilling out oil if it only opens at an "elevated" pressure. If that is the case, all you need is to get a new one.
Not sure if driving without it to test it will cause even more oil to leak out.
2010 - Unleashed Tune - Corsa Exhaust - 275/40-R20 - H&R Springs
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« Reply #9 on: January 26, 2022, 08:50:25 PM »
Going to try that. I will see if I can remove it and clean it up as well or just replace it. I didn`t think there was any pressure there but who knows. Thanks for the help
Offline Mksmark
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 4
  • Ecobooster
  • Liked:
  • Likes Given: 2
« Reply #10 on: March 06, 2022, 03:07:17 PM »
Well before I could get to this problem, some idiot made a left turn right in front of my wife and now the car has $5000. worth of damage to the front end. She is fine.  I`m in the Chicago area and it looks like its going to take 3 months to get the dam thing fixed. I cant win.  :bangin:
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13071
  • -Received: 4265
  • Liked:
  • Likes Given: 186
« Reply #11 on: March 13, 2022, 07:13:46 AM »
ouch. hope you can figure rdu repair into the estimate ;)
