Hot Pipe group buy
Started by EcoPowerParts, September 11, 2013, 12:55:33 AM
EcoBrick Bob
Quote from: TaurusBuilder on December 14, 2013, 08:54:40 AM
Quote from: EcoBrick Bob on December 14, 2013, 08:39:27 AM
The Hot Pipe install should be pretty straightforward.  You are starting at a good place (pipe from intercooler to TB).  After you remove each piece, you re-install with hot pipe piece using the silicone connectors that are the right size, and appropriate new clamps.
I would have done an install pix, but I can't install until I get my silicone connectors & clamps.  They accidentally didn't send the connectors with the hot pipes..  Long story but they are now at my son's house in IA where I will be late next week.
I'm not really confused on pipe placement as I am on closing the BOV's to and hooking up all the vacuum lines for the Tial BOV. It also looks a little tight in the back near the rear turbo. Would rather have exact instructions rather than a trial and error.  I'll wait if you plan on doing a write up.  Not in a huge hurry. But want it on the car before the old lady sees the evidence that I've been spending money.
I don't have the Tial BOV, which means my info wouldn't help you much.  Forgot about you getting 4 DR's.  He will have to walk you through it.  Did he send you the resistor to handle the stock BOV's?  The Nitrous hole across from the sensor in the pipe from IC to TB will need to be plugged, if 4DR didn't send a plug with the system.  Mine came with that hole also, but BPD's didn't.  What I found that fit is a 5/16" 24 bolt 3/4" long that I got at Auto Zone.  Came in a package of 3.  Because the threaded part needs only to be about 3/8" long ( length not available - bought shortest I could find), I cut it off before permanently installing.  Also used some sealant (oil resistant type) during final tightening.  I would have rather used a brass plug, but couldn't find any that small and with the correct thread pattern.  Before I actually install that pipe, I am going to drill a 1/8" 27 NPT hole  which is the size of my Methanol Spray nozzle(s). That  11/32" hole will be drilled in the bottom of the pipe as far forward as possible, just behind the silicone connector to the TB. I have the proper NPT tap for the threads  (from Amazon).
Naples, FL & Clear Lake, IA
EcoBrick Bob
Quote from: SHOdded on December 14, 2013, 10:01:22 AM
Midwest supposed to keep getting hammered, EBB.  Safe drive back to IA, for the hot pipe installation :)
Leaving Tuesday.  First night just north of you.  2nd night near Rockford, IL ( business meeting Thurs AM) - and hopefully IA late Thurs Afternoon.  Snow I can handle... HATE ICE!
TaurusBuilder
Quote from: EcoBrick Bob on December 14, 2013, 10:03:33 AM
Mine came like bdp's. Without the hole. I guess I'll just have to figure it out. But it didn't come with resistors or anything. Just pipes and clamps and such. The way 4dr explained it, I should pretty much follow the steps for the VTA only change 1 parts of it. He sent it to me. But I like dummy proof so I can see it. And unfortunately the shops around here are geared toward imports so they look a little confused when I tell them what I got. Will see. Today's mod is the LMS down pipes. Car is on the rack now
Soon to be fastest MKS on the planet!
Mods: Magnaflow exhaust with cut-outs, Ecoboost hot pipes with BOV, Injen intake, Livernois 4+ tune,LMS downpipes,NGK spark plugs, 170 thermostat, RK sport roof spoiler........lots more to come
EcoBrick Bob
Quote from: TaurusBuilder on December 14, 2013, 10:21:29 AM
Wish mine didn't have the hole... It is what it is.
Greg.....
I did NOT get the aftermarket BOV w/ these pipes.
As you can plainly see in my picture, I have the flanges to use the stock, electric BOV's.
Hopefully my mechanic friend finishes up plowing all the snow that recently fell.....
If so, we will be in aiming for install Monday morning.
However, I do work Monday and Tuesday night, therefore the soonest any right up maybe coming from me, would be Wednesday or Thursday of next week.
At the soonest.
But like EBB previously stated, the install looks fairly straightforward and merely involves removing the stock pieces and reinstalling the new pipes in the same spots.
OK, let me clear some things up:
1. The first four set of pipes had the nitrous hole/mount put into them, I didn't ask for it he just copied my pipes.
2. For the Tial BoV just connect into a post throttle body boost source, easiest way is to cut the brake booster line and T it to a 5/16" line to the Tial. Leave the factory BoV connected to the harness and just zip tie, they fit easily under the factory cover, you can't see them due to the gigantic piece of plastic... :) As Bob found you just take the pipe with the nitrous hole down to the local hardware store and get a screw. I had the pipes built and drop shipped from PPE, they didn't have access to put a screw in the pack unfortunately.
3. The assembly is pretty straight forward:
The 3" to 2.5" pipe goes from the TB (3") to Intercooler (2.5") - short fat bent one with TIP sensor mount
The 1.5" to 2" short slightly bent pipe goes to the front turbo and will have the 1.5" straight on one side and 2" straight on the other side to go to the intercooler.
The pipe with the mounting tab goes to the back turbo and requires a 1.5" to 2" reducer to go to the turbo.
The left over pipe connects to the back turbo pipe and then to the intercooler, it uses the 2" hump hose and 2" straight, hump hose to the other pipe and 2" straight to the Intercooler.
For the factory BoV pipes just mount them with factory screws and then connect to harness, they vent to atmosphere
For the Tial, just hook to the boost source I stated above. The key is the Tial must be connected to a vacuum/boost source AFTER the throttle body.
If the pipes hit the factory air box you can clearance the box to fit, the opening is on the "outside" of the filter so if you suck in air there it's not a problem due to being filtered after.
TaurusBuilder
Thanks for the clarification. I'm going to try it 2morw. Super excited.
bigmoneycloser
No one has these for the Xsport, right?
2014 Explorer Sport 401A
I don't believe there is a US manufacturer... possibly UK or China, but I think the shipping would be prohibitive.
Quote from: bigmoneycloser on December 14, 2013, 03:06:56 PM
I need to find somebody who owns explorer sport in Arizona so that I can test but these
Sent from my SCH-I545 using Tapatalk
bigmoneycloser
Stuck in jersey...
dcpatters
Quote from: 4DRHTRD on December 14, 2013, 03:25:41 PM
Where is AZ?
2014 Explorer Sport LMS tune, 170 Stat, Airaid
Phoenix
Three question. What about ceramic coating like jet hot, what the hell is that thing hanging off the side of the factory intake before the throttle body.  And why are you calling these hot pipes..they support the cold side of the turbo. Intercooler  or intake piping makes much more sense. I was very confused about what you were selling from the topic header. After seeing the pictures it was quickly cleared up.. thank,
Quote from: panther427 on December 14, 2013, 09:15:53 PM
It's just what the "new" name is for the pressurized piping. The cold pipes are actually the pre-turbo pipes, hot pipes are post turbo unless you're thinking exhaust, that's called a manifold and a downpipe.
The thing hanging off the pipe pre throttle body is a Tial blow off valve to replace the factory ones.
