Yeah, this is happening at the worst possible time. Lots going on in my personal life.
All that BS aside, i am creating a spreadsheet of possible parts required / wanted. Of course My brain is in over drive / Worst case mode. I need some opinions from you good folks.
Should i replace the entire PCV systems along with the Turbos? I was already experiencing some oil build up on the PCV valve and had been wanting to at least replace that, but now i am thinking about how much oil went through the motor / Intake track. How much of the emissions system got oil soaked, or will get oil soaked after the repairs?
https://parts.levittownfordparts.com/v-2014-ford-taurus--sho--3-5l-v6-gas/emission-system--emission-componentsIts not to expensive parts wise to replace most of it.. The labor is what kills the wallet after all.
I should know more Monday evening if the mechanic gets around to dropping the oil pan pulling turbo, etc. etc. I fear i am going to have to make an extensive list of actions i want him to do in addition to the basic repair action, such as cleaning all the oil out of the intake system.
I am currently estimating repairs to be around the 10G's area, (I will replace the Down pipes, O2 Sensors, and CAT Back along with the turbos and Blow off Valves and control solenoid). I also need to Have him replace the CV half shafts, drivers side front is a bit noisy, if you do one do them all...
Any input from the Community is welcome, positive or negative...
V/R,
The Terror
