- RotM Winner
- Elite Member
- Boosted
- Logged
Randy did you do any performance test yet? Idling and ambient vs IAT2 part or WOT compared to before? I know you did some towing but you compared IAT2 to coolant temp and no comparison or even actual numbers just that it was 90° cooler than coolant. Leaves a lot of info still to be desired. Isn't the whole point of the spacer to decrease heat soak and give better performance (race related)? With towing in my SHO I don't, and never will, also if I did I would only be concerened with trans temp period. I'm not sure why giving vague data from towing was all that could be shared.
Sent from my LM-G710VM using Tapatalk
