Detailing, SYNC, AV, Security, Electrical, and Lighting
Interior Modifications
Radio reception/antenna
Started by slimshamis, March 03, 2020, 08:27:11 PM
slimshamis
Newbie
Ecobooster
Last Edit
: March 03, 2020, 10:36:53 PM by slimshamis
My radio reception has always been kind of poor but now every channel is staticky on my 2010 SHO when I do the bezel diagnostics and signal strength it says am/fm antenna failure anyone have this issue and a fix?
Forum Supporters
Re: Radio reception/antenna
March 04, 2020, 05:36:26 AM
http://www.nicksmustangranch.com/Service_Manuals/2014/2014_Taurus/Resources/Service_Manual/seff0a03.htm#table_extract_33
You will have to run through the tests in pinpoint test A. This results in checking the alternator, grounds, antenna grid, antenna module, antenna cable, and ACM in that order.
Hopefully it is just a ground issue, or perhaps water/grime intrusion into the electrical connectors at the ACM.
