February 20, 2020, 01:00:46 PM
Author Topic: Blower motor removal?  (Read 2667 times)
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« on: January 20, 2020, 05:38:07 PM »
Hi so I took the car to the car wash where it's very humid I had turned on the AC to keep the windows from fogging but then the next day my blower motor was frozen from moving.
Put a heater on it then it started working again about three hours later  when it's -30f. Next day it froze again after getting it very hot for an hour.
So I'm curious how do I get to the blower motor so I can wipe out the moisture.
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12499
  • -Received: 4109
Re: Blower motor removal?
« Reply #1 on: January 20, 2020, 07:55:57 PM »
If it is anything  like the Edge, you drop the glovebox to get at it from underneath.  Look up the MACTFORDEDGE  channel on youtube.
https://youtu.be/UmlmDJf6xw8
http://www.nicksmustangranch.com/Service_Manuals/2014/2014_Taurus/Service%20Manual.htm
Procedure:
« Last Edit: January 21, 2020, 09:58:54 AM by SHOdded »
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #2 on: January 21, 2020, 09:36:50 AM »
I hope it's that easy going to attempt it on lunch
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12499
  • -Received: 4109
« Reply #3 on: January 21, 2020, 09:59:22 AM »
Should be.  Updated post above.
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #4 on: January 21, 2020, 03:08:29 PM »
Thank you I didn't check back before doing but I'd like to add that the rear left screw is reverse thread I tried for a few minutes the right way notice it didn't even budge tried the other way and it came loose
Here are the photos of the motor.
I had a heater on it the area was very warm w/ also auto started it for 30 minutes not sure if all that dried the water out but it was completely dry just can see the red soap or wax dried on there.
I left the panel off so if I need to replace it or give it a gentle kick to turn it back on it should be much easier.
The motor turned freely.
You will need a 7mm and 8mm 7 first 3 then 8 for the motor.
« Last Edit: January 22, 2020, 06:22:58 PM by Gjkrisa »
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12499
  • -Received: 4109
« Reply #5 on: January 21, 2020, 06:57:53 PM »
I would have sprayed liberally with electronics parts cleaner to get it cleaned out, but not sure if it has exposed greaseable parts or not.
Fingers crossed, it's back in business.
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #6 on: January 21, 2020, 07:02:57 PM »
Yea didn't think about that I really want to.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • -Given: 1833
  • -Received: 3889
« Reply #7 on: January 22, 2020, 04:53:52 AM »
It might be worth to also check the Blower Control Module Resistor if its not functional!  [9L3Z19E624B].They work in accordance to each other.
Btw check the cabin air filter to verify it's not wet. Z
https://www.fordpartsgiant.com/parts/ford-control_9l3z-19e624-b.html?Vin=1FAHP2KT5DG183206&Filter=()
« Last Edit: January 22, 2020, 03:37:52 PM by ZSHO »
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #8 on: January 22, 2020, 09:36:23 AM »
Btw check the cabin filter to verify it's not wet. Z
Oh man your correct I should have first checked the cabin filter the first time it froze
Well it worked this morning.
I'll check the filter at lunch.
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #9 on: January 22, 2020, 02:49:53 PM »
Well the filter had no signs of water in it completely dry
Does any one know of an easier was to get the filter cover off the left one has to many sharp edges in the area.
Maybe just use mechanic gloves.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • -Given: 1833
  • -Received: 3889
« Reply #10 on: January 22, 2020, 03:17:11 PM »
Grab a pair of needle nose pliers and pull the bottom TAB UP and should pop off.
Alternative is using a mini flat head screw driver and insert it behind the TAB and PULL IT UP & outwards. Z
« Last Edit: January 22, 2020, 04:20:36 PM by ZSHO »
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 942
  • -Received: 206
    • Photos
« Reply #11 on: February 05, 2020, 08:12:30 PM »
Ok now the blend door isn't operating I thought that was frozen but won't work still when I had heat in the car for 8 hrs same as before
It did kinda show signs of going out I was messing with forscan and in the error codes said the motor circuit was closed but then restarted the car and everything was fine...
So I know I have seen at least one post on this but how would I diagnosis this issue or do is there one main motor to replace for the blend doors?
Right now I believe it's just stuck on panel mode.
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12499
  • -Received: 4109
« Reply #12 on: February 05, 2020, 11:05:01 PM »
http://www.nicksmustangranch.com/Service_Manuals/2014/2014_Taurus/Resources/Service_Manual/sefc1024.htm
If it is stuck as to where the air is directed, that is a mode door actuator issue.  There is one mode door actuator for defrost/panel/floor as linked to above.
* Featured Topics
* Recent Topics
Re: Have you spotted SHO on these rims<<<<<
by jims2015 | Today at 09:38:33 AM
Well, I asked my graphic design department at work to photoshop wheels...
Re: 10ECOMKS '10 MKS Build / Maintenance Thread
by SHOdded | Today at 08:29:36 AM
Blackstone is always worthwhile.  Given that your MKS already has...
Re: Misfiring codes P0300, P0302 and P0306
by ddlopes | Today at 05:53:55 AM
Looks like the SP578ís that are replacing the SP542ís arenít the same ...
by nickstewartroc | February 19, 2020, 09:08:25 PM
Sounds about right for a set of catted pipes...
by SHOdded | February 19, 2020, 06:03:33 PM
I am too old I guess.  I am living my 2nd childhood....
Re: Anyone know what the MSD coils put out versus the OEMS?
by 802SHO | February 19, 2020, 10:28:33 AM
I am really impressed with them as well.  I keep my stock coils i...
Re: 2014 Lincoln MKS EcoBoost with all the goodies $12,900.
by nickstewartroc | February 19, 2020, 10:16:34 AM
Black SHO?Yup.  Seemed like a real good dude too.  He offere...
Re: AFE Cold Air Intake
by SHOdded | February 18, 2020, 03:39:15 PM
Very cool!...
Mustang - Taurus suspension comparison
by Gjkrisa | February 18, 2020, 12:42:58 PM
Hi does anyone know the suspension dimensions?Front struts monting to ...
Performance Budget tires
by ZSHO | February 17, 2020, 08:06:05 PM
Performance budget tires that should meet or exceed anyones expectatio...
Re: New '10 EB MKS owner
by PDSHO | February 17, 2020, 12:48:21 PM
Re: Donít see much on here about ***. Looking at them, Gearhead, and AJP
by lamrith | February 17, 2020, 12:02:29 PM
I also noticed on the way to work the other day I was behind a limited...
Re: New rims...not your average XSport setup
by Ls2bait | February 17, 2020, 08:36:49 AM
Posting from iOS?Yes...
Re: SHO whining noise?
by Code AiR | February 16, 2020, 07:21:04 PM
Check the PTU fluid for level/condition.Good point, I'll do that ...
Re: Rear window leak?
by TopherSho | February 16, 2020, 02:37:46 PM
Yeah this is the rear REAR glass, back passenger was up for sure as I ...
Back to top
