- RotM Winner
- Elite Member
- Boosted
- Logged
Your fuel pressure dipped that low (momentarily) or stayed that low during your entire WOT pull? Meth isn't going to make up 50% + of your fuel pressure I think more like 20% at best. When's the last time you changed your primary O2 sensors? I had a similar experience, it was actually after I replaced my O2's and occured a few datalogs later. It dipped for a second to about 1100. Never to occur again.
But Topher is right you should replace the pump. I replace mine every 2 years.
