3rd cat & resonator delete feedback
Started by Mossdahaus, September 01, 2019, 07:10:07 PM
Mossdahaus
So I had a bright idea to order a replacement Xpipe from one of the major catback manufacturers to bolt in a resonator & 3rd cat delete.
Looking for feedback on tone, volume and rasp to go along with my current SW catted downpipes and stock mufflers on deleting these 2?
2015 Taurus SHO - Performance Pkg & Nav
SW catted DPs, Ford Racing exhaust, MSD Coils, SP542 Plugs, 170 tstat, 3bar MAP sensor, XDI-35 HPFP, modified Airaid intake, GH Intercooler, 18+ trans mount, JLT catch can & AJPTurbo E30 tune
802SHO
The Xpipe will make it louder and it will probably get a little rasp but I think it will sound less raspy with your mufflers than if it were straight piped. Overall I think you'll find a little bit of rasp easy to live with.
Chaplain
I believe I have mostly done what your asking about to my '17 Explorer Sport.
From stock down pipes, exhaust goes into a 2.5" magnaflow X-pipe, then out into two straight 2.5" pipes back into twin Magnaflow hiflow mufflers (this section is Magnaflow's 2.5 explorer's setup.)
Sounds ok but dont expect a v8 sound. It's not loud but people will recognize you have an exhaust immediately.  You can hear the turbo's spooling out the exhaust which is cool.
Thenewguy
Quote from: Chaplain on November 29, 2019, 12:23:11 AM
Hey Chaplain,
I know this is an old post but I saw your pictures and sent you a pm, not sure if you got the chance to see it so i thought id just replay to this post. Hows that setup been for you? I have PPE catted DPS and oem 3rd cat and resonator. I had my mufflers replaces with some vibrant ultra quiet resonators. I find its a good balance where it keeps the muffler delete drone we all experience at bay but i wanna wake it up a little bit more. I was thinking of straight piping the resonator and keeping the 3rd cat oem cause a lot of people have mentioned the minute they remove that, a lot of rasp develops. Hows your x pipe with the resonator delete been? I know youre not exactly the same setup as me but you have aftermarket mufflers like me so maybe i can gauge what its like living with this setup daily
kryptto
#4
Do you mind sharing the part number ofDescriptions.  Or should I ask if that is the:  MagnaFlow 2.25in. Tru-X Crossover Performance Exhaust X-Pipe 10790
2014 Ford Taurus SHO PP Darkside - PPE Catless Downpipes, coated and wrapped - ECO Power Parts Noisemaker Delete - 3BAR MAP - Torque Solution BOV VTA - J&L Oil Catch Can - Ford Performance Spark Plugs Colder Range - K&N CAI, Reisch 170 degree thermostat, Forscan, HP Tuner & Tuned by Daily American Racing, Accel Coil Pack, FULL Chrome Delete - Sync 3 Nav System - Ford Taurus SHO Badge Delete - XB LED Mirror Puddle Lights - Full interior LED upgrade - Custom rear window "wing"
