August 05, 2021, 09:58:01 AM
Author Topic:  Dash Cam installation  (Read 4255 times)
Offline lamrith
  • PNW
  • -Given: 107
  • -Received: 391
  • Liked:
  • Likes Given: 1
« on: August 21, 2019, 01:49:35 PM »
Recently the number of near misses I have had/seen on my daily commute has gotten extreme.
A month ago I saw the truck in front of me broadside (lightly thankfully) another car because the other car had run a redlight.  We were sitting at a red light, it went green and thankfully he was very very slow off the line (I almost tooted he was that slow), otherwise she would have hit him in the door at full speed.  The truck driver is very lucky I decided to stop and give him my info because the other driver insists she had a green light and since he hit her, it would have been his fault (officer that called me for a statement told me that) Nobody else stopped and it was a He said, she said.  She is fighting it hard too because I have also had calls from lawyers about it.
Fastforward to last week and I was coming up to a light that was green for a good minute or more before I got to it.  35mph, just as I cross the line a vehicle runs the light from the left at full speed.  I still do not know how I stopped fast enough to miss him, but these AS-05's stop hard and stop RIGHT NOW.  These are just the two most recent, the number of people using their cars like a weapon/armor is just thru the roof.
So I have purchased a dash cam.  It activates on power on, the problem is that the SHO the Cig lighters are always hot.  Right now I am plugging it in each time I go for a drive and unplugging when I park.
SO!  What have you guys done to hardwire your dash cams in?
Offline SHOme
  • Full Member
  • Maryland
  • -Given: 32
  • -Received: 22
  • Liked:
  • Likes Given: 0
Re: Dash Cam installation
« Reply #1 on: August 21, 2019, 03:00:47 PM »
I have my radar detector hard wired to the map light.  It hangs tight to the mirror mounted on the mirror post. It turns off when the car is off.
2014 SHO, PP 3 bar, 160 T Stat, Livernois v10 Tune, UPR catch can. MDesign CAI
Offline nickstewartroc
  • Sr. Member
  • Orlando, Florida
  • -Given: 6
  • -Received: 95
  • Liked:
  • Likes Given: 0
« Reply #2 on: August 21, 2019, 03:36:54 PM »
I've done this as well for my dashcam in my SHO
Current:
Offline lamrith
  • PNW
  • -Given: 107
  • -Received: 391
  • Liked:
  • Likes Given: 1
« Reply #3 on: August 21, 2019, 03:42:14 PM »
I didn't realize the map light comes on with the car?  I will have to look into that, and also verify voltage this cam uses.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13054
  • -Received: 4248
  • Liked:
  • Likes Given: 25
« Reply #4 on: August 21, 2019, 04:21:22 PM »
Stay safe out there, amigos.  It IS the start of a new school year, and open season for new/inexperienced drivers.
Offline lamrith
  • PNW
  • -Given: 107
  • -Received: 391
  • Liked:
  • Likes Given: 1
« Reply #5 on: August 21, 2019, 04:35:05 PM »
Very true.
Sadly, all the ones I shared were middle aged adult drivers.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #6 on: August 21, 2019, 05:46:55 PM »
« Last Edit: August 21, 2019, 06:00:50 PM by ZSHO »
Offline lamrith
  • PNW
  • -Given: 107
  • -Received: 391
  • Liked:
  • Likes Given: 1
« Reply #7 on: August 21, 2019, 06:29:12 PM »
This kit should work as it does not exceed the minimum threshold of 5V/2A AFAIK!
X2- Slow down and Stay safe as the new school year is upon us.
Here's my personal "How To" below!
https://www.ecoboostperformanceforum.com/index.php/topic,9669.0.html
https://www.amazon.com/AUCEE-Dash-Cam-Hardwire-kit/dp/B077C1HTPK/ref=sr_1_fkmrnull_1?keywords=AUCEE+Dash+Cam+Hardwire+kit%2C+Mini+USB+Port%2CDC+12V+-+36V+to+5V%2F2A+Max+Car+Charger+Cable+kit&qid=1552953937&s=gateway&sr=8-1-fkmrnull
Thanks Z!!
I was sure you had a write-up, but I was looking for dash cam.  :-p
I see you have a dash cam mounted, did you use the long cord you linked here and just run it to direct power source rather than tap the mirror?
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #8 on: August 21, 2019, 06:36:48 PM »
Thanks Z!!
I have tried both methods and worked as designed. Bit of trial and error per se. Z
« Last Edit: August 21, 2019, 06:39:54 PM by ZSHO »
Offline Nova
  • Full Member
  • -Given: 82
  • -Received: 96
  • Liked:
  • Likes Given: 0
« Reply #9 on: August 21, 2019, 09:27:53 PM »
Thanks Z!!
Could you power both a dash cam and a radar all from the mirror tap?
Sent from my SM-G965U using Tapatalk
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
« Reply #10 on: August 22, 2019, 07:13:36 AM »
Thanks Z!!
I would not recommend it IMHO! To much power going into one souce. Z
* Recent Topics
Re: Any advice on how to improve 1/4 mile times?
by Blackhawk | August 04, 2021, 11:46:49 PM
This car should be running at least high 11s with all those mods. ...
Re: Terrain Management System Fault - wrench light
by TopherSho | August 03, 2021, 05:45:56 PM
Good notes to keep under the hat,  thanks for the share and updat...
2010 Taurus SHO, PCM issues
by withku | August 03, 2021, 01:41:48 PM
Hey all, my 2010 has been acting up lately. A while ago, my a/c stoppe...
Re: PTU 2017 3.5 EcoBoost Explorer 20 minute Fluid change all from underneath car
by SPDboat driver | August 02, 2021, 06:28:36 PM
Good video. You think you may lose some fluid through the vent if it h...
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | July 30, 2021, 08:24:58 PM
Even though I haven't been posting as frequently lately (YouTube ...
Re: 15 Interceptor Sedan Ecoboost with GHT Tune - Engine Coolant Overtemp
by SHOdded | July 30, 2021, 02:58:41 PM
on the 2.7, ford says to replace the ECT sensor and/or the knock senso...
Re: Random Pull/Torque Steer after new moog lower control arms.
by SHOdded | July 30, 2021, 02:54:07 PM
have an independent service shop verify your work with the LCAs. ...
Boost / Vacuum Source
by Ecoboost_xsport | July 29, 2021, 12:36:21 PM
Those of you wondering where a decent place to tap into a boost/vacuum...
Re: New from Minnesota...
by PDSHO | July 27, 2021, 04:15:43 PM
Re: Ol' Guy in New England........
by PDSHO | July 27, 2021, 04:13:04 PM
