- RotM Winner
- Elite Member
- Boosted
- Logged
When I worked at a shop detailing and tinting, one of the techs helped me(or I helped him) install mine on a lift over the weekend. All the compressors were turned off, not sure why we didnt turn them on...so he did it by hand, well with a breaker bar..penetrating lube....torch..Had to replace 3 studs. Was able to use the original O2 sensors. Came with its share of issues, leaving and going to buy studs to replace the studs we used from the shop. Definitely took longer than previously anticipated. Overall it wasnt as rusted as expected with the weather up North. Car is from MA but its the same weather.
