Definitely inspect the exhaust system (OEM?) closely. Flex pipe may be cracked, bolts may be loose, etc. It may also be indicative of incomplete combustion, might be worth installing a new set of plugs if the OEM plugs came with the car. No codes in the PCM, right?
