Quote from: gtmorgan23 on February 09, 2018, 01:29:52 PM
I wonder if there is a thread on here for subs enclosures, install and pics.
Id love to see some if there isnt. Just something enjoyable about bassing out while cruising in your ride.
Well since you asked......
Two (2) - 15" subs, forward firing and positioned atop the "shelf" in the trunk.
Two (2) - 12" subs, each mounted in the far corners of each side of the trunk.
All powered by four (4) class D digital amps.
Two (2) amps are 1000x4 watts each and the other two (2) amps are 600x4 watts each.
The amps are powering other aspects of the audio build, besides just the subs.
I actually had to de-tune the amps (turn the power down on them) as I noticed a sticky brown tar like substance pooled up in each corner of the rear drip tray at the bottom the of the rear windshield.
Turns out that that was/is the adhesive used in securing/mounting the rear windshield. Apparently I was on the verge of literally blowing the rear glass out from its' frame.
Oops!
