July 06, 2020, 01:35:09 PM
Author Topic: PTU Oil Change (Tons of Pics) 2016 Explorer Sport  (Read 23893 times)
Offline Lexingtonian
  • Full Member
  • -Given: 9
  • -Received: 45
Re: PTU Oil Change (Tons of Pics) 2016 Explorer Sport
« Reply #30 on: August 01, 2017, 04:41:20 PM »
to embed the video, use this link instead
! No longer available
Basically, the full URL, and http instead of https.
I tried it but it still doesnt embed right. Ideas? Thanks!
2016 Explorer Sport Metallic
93 Octane AJP Tune (SCT X4)
3Bar MAP
Plugs at .030
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1935
  • -Received: 4070
« Reply #31 on: August 01, 2017, 04:51:12 PM »
@-Lexingtonian due appreciate you taking your time to post/share some important,informative pics for the Ecoboost community.  Z  :thumb: :thumb:
« Last Edit: August 01, 2017, 04:56:58 PM by ZSHO »
  • Full Member
  • -Given: 9
  • -Received: 45
« Reply #32 on: August 01, 2017, 10:57:55 PM »
Happy to help!
3Bar MAP
Plugs at .030
Offline 68_GT
  • Houston TX
  • -Given: 16
  • -Received: 55
« Reply #33 on: August 02, 2017, 12:26:03 AM »
I pulled my engine to extend the PTU vent hose up so I can drain and fill it. I'm at 135k miles on the original PTU fluid :)
OK so actually I extended the vent hose up while installing a new long block lol ugh.....
gotta get this done. how much gear oil goes in and recommended brand ?
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
« Reply #34 on: August 02, 2017, 12:32:36 AM »
Official fill capacity is 18 ounces.  Recommended brands?  Everyone has a favorite, but Amsoil, Redline, Royal Purple, Mobil1 and Valvoline top most people's lists.  Motorcraft if you intend to R&R at shorter intervals.
Offline DirtyHarry
  • Newbie
  • -Given: 0
  • -Received: 6
« Reply #35 on: October 14, 2017, 09:47:08 PM »
This is for a 2016 Explorer 4wd non-turbo to add the extension for the PTU breather tube;
1. Buy 2' 5/16" Id  fuel line hose from your local parts store (2.99)
2. Buy 5/16" splice nipple fitting from True Value (1.99)
3. Remove the air box snorkel and the throttle body- no need to unplug
4. Locate the Breather tube, mine had a yellow tag. Use two wire ties to hold the top while cutting the rubber tube with side cutters. DO NOT cut the wire connector holding the old tube in place! Pull the cap out and carefully cut the old hose off it.
5. On the new hose, lube the nipple connector and push into hose end
6. On the old tube, lube the fitting with new hose, and slowly wiggle into the tube. You might need to hold the old tube but it should stay.
7. Run new hose up around throttle body area and place old breather cap back on, lube it too.
8. replace throttle body and snorkel assy.
Offline DanJett
  • Jr. Member
  • -Given: 1
  • -Received: 2
« Reply #36 on: November 28, 2018, 10:02:56 AM »
I think I'm going with this method instead of replacing the whole hose. Seems easier.
Thank you!
Offline youtek
  • Newbie
  • -Given: 0
  • -Received: 1
« Reply #37 on: January 05, 2020, 07:06:38 PM »
Thank you for posting this. I have a 2016 xplorer sport gray metalic with 34k miles and I did the PTU oil change today with the guidance of this post. PS I could n't tight the brace from 5/16 hose I couldn't make it with sucha as small room. Also, with the filling, mine took over 3 hours to fill due to tje hydrolock. When you say give some space for the funnel you mean not to fill all the way up? and rather wait to be empty when adding more fluid? Thanks very much!
  • Full Member
  • -Given: 9
  • -Received: 45
« Reply #38 on: January 06, 2020, 12:13:47 PM »
I'm assuming you're saying you couldn't tighten the cable clamp down at the bottom of the 5/16 hose connected to the PTU vent nipple? It's tricky for sure, it needs to be done from underneath the vehicle and you're completely blind.
As far as the oil draining in, hopefully you measured how much you drained as that's how much that needs to go back in (plus maybe and ounce or two for good measure). Yes if the oil is left to sit and drip in on it's own it will take hours so that's normal. These days, I jam the oil bottle nipple into the 5/16 hose and force it down the pipe by squeezing the bottle. It goes in in minutes that way.
glad the post was a help! Let me know if there's anything else I can do for you.
3Bar MAP
Plugs at .030
Offline youtek
  • Newbie
  • -Given: 0
  • -Received: 1
« Reply #39 on: January 10, 2020, 02:32:27 PM »
Yes, I couldn't tight the clamp down at the bottom of the 5/16 hose. I'm afraid this will leak some oil in the future, I will try to tackle this on the next PTU fluid change. As for the fill time, after 3 hours waiting, I decided to  spin vehicle a little bit forward and then finally all the new fluid came in. I was able to drain 13 oz of fluid and put same amount back with new fluid.
* Recent Topics
Re: Has anyone install custom Hood?
by sm105k | Today at 01:00:52 PM
There are at least two guys who purchased the fiberglass version. One ...
Re: SHOdded Officially Retiring as Admin
by bpd1151 | Today at 12:10:01 PM
Thank you Manu for your work and dedication to the community.Enjoy the...
Re: Edge ST .......Here she is
by sm105k | Today at 11:23:02 AM
I really like it.  How is the room?  Maybe one of those will...
Re: Finally bought an XDI35 HPFP
by bamsho | July 05, 2020, 10:30:50 PM
If you're 60 ft would have been the same you would have beat it e...
Re: New SHO owner with problems
by 802SHO | July 05, 2020, 07:25:06 PM
Good luck but I don't like the sound of them being so quick to ju...
Re: Traded in the SHO.......
by Macgyver | July 04, 2020, 11:05:20 PM
Finally Done. Had to go to a different dealer as the original dealer r...
Re: New Moderator
by sm105k | July 04, 2020, 02:31:56 PM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | July 04, 2020, 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Back to top
