Looking at AFR numbers
Started by Shmike281, January 30, 2017, 06:52:27 PM
StealBlueSho
Looks like mine if I were to do a second gear only pull.
StealBlueSho
Quote from: AJP turbo on January 30, 2017, 10:19:04 PM
Desired Lambda at WOT for a 2010
Interesting, I could post my log, but under WOT, stock, my desired lambda is .68 in second gear along with most of third. This is significantly richer than the table you posted.
Quote from: Shmike281 on January 31, 2017, 12:21:21 AM
Okay here is the log from the sct x4. Run is a second gear pull 2k rpms to 6500, wot. The gold line is rpms the red is afr bank 2 the green is afr bank 1. The car is on the oem tune with 93 octane. Outside air temperature was about 55 degrees.
I would be more worried if AFR1 deviated significantly from AFR2, in general terms.  Your data shows very minor blips, nothing to be concerned about.
Quote from: StealBlueSho on January 31, 2017, 05:11:17 AM
There are modifiers also
But OP the screenshot looks normal...enrichment doesnt happen until really late and then goes really rich
StealBlueSho
To the OP, if both banks agree on AFR,  and we can say that you AFRs look normal, then I wouldn't be worried about a tune.
If you log LAMBSE you will see what the target afr should be...then just check that against measured lambda.
Now its time for boost and a tune sir
MiWiAu
Quote from: AJP turbo on January 31, 2017, 09:39:29 AM
Then you can officially join the AJP Turbo "Nut-Huggers" convention, as @Colorado-SHOBro so eloquently dubbed it!
http://www.ecoboostperformanceforum.com/index.php/topic,7369.msg112287.html#msg112287
2013 XSport
#22
Careful....im not sure if you are allowed to say nut hugger on this fine forum...might be too strong of language....im afraid to say the word damn or hell without fear of retribution ...moderators will pounce
Not a bad practice though in case 3 year olds learn to read
I think you give 3 year olds too little credit.
StealBlueSho
Quote from: AJP turbo on January 31, 2017, 10:03:54 AM
It does keep the forum discussions on track... not bad IMHO..
derfdog15
Quote from: ZSHO on January 31, 2017, 04:56:57 PM
Wait wait wait.... we go from nut huggers to Z asking for a hug? So, is Z a nut? #Askingtherealquestions
Quote from: derfdog15 on January 31, 2017, 05:03:40 PM
No nut hugger here but an all out but hugger.lol.  Z
