July 04, 2020, 11:40:56 AM
Author Topic: Swapped to PP trans by-pass T-stat (and coolant T-stat)-results  (Read 17566 times)
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 119
  • -Received: 131
  • SHO-NUFF
Re: Swapped to PP trans by-pass T-stat (and coolant T-stat)-results
« Reply #15 on: October 06, 2017, 08:53:18 PM »
If you are buying the PP bypass valve, then why do you need to swap the thermostat on it? Are the PP and non PP valves different?
the only difference in the PP and non PP valves IS the Tstat. and you change the t stat because it's a hell of a lot easier than changing the whole by pass valve.
Maybe I'm missing something which is possible. The doohickey in the picture with the 2 lines on one end is the bypass valve? Correct?
Once it's out you swap the thermostat?
If the cost is minimal like it seems couldn't you just swap the whole doohickey? Just insurance and a new bypass valve just in case.
2011 SHO, 3 Bar 93 LMS stage 4+x, ACES IV, 170 T-stat, PPE Catted DP's, Alpine Sound system, Touch screen HVAC controls, full window tint
Offline Colorado-SHOBro
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #16 on: October 06, 2017, 09:22:32 PM »
you don't remove the by-pass valve block doo hickey in the pic. it stays in the car and you just swap the cooler thermostat in. much easier than disconnecting your trans lines and replacing the whole block- that would be like removing your intake manifold to swap thermostats lol
12.8@108 @ 6,000ft DA.
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 119
  • -Received: 131
  • SHO-NUFF
« Reply #17 on: October 07, 2017, 12:43:28 PM »
Got it. Thanks for clearing that up for me!
Offline Dxlnt1
  • Elite Member
  • Los Angeles, CA
  • Thank You
  • -Given: 119
  • -Received: 131
  • SHO-NUFF
« Reply #18 on: October 07, 2017, 01:29:29 PM »
I cannot find that part number with Tasca. They gave the DG9Z-H322-A. Ims it the same specs?
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #19 on: October 07, 2017, 01:40:26 PM »
This part is pointing to the Escape, MKZ, etc. not the Taurus.  So IDK if it will fit.
THIS PART FITS
Make   Model   Year   Body & Trim   Engine & Transmission
Ford   Escape   2017   SE, Titanium   1.5L L4 - Gas, 2.0L L4 - Gas
Ford   Escape   2016   S, SE   2.5L L4 - Gas
Ford   Escape   2015   S, SE   2.5L L4 - Gas
Ford   Escape   2014   S   2.5L L4 - Gas
Ford   Fusion   2017   Platinum, S, SE, Sport, Titanium   1.5L L4 - Gas, 2.0L L4 - Gas, 2.5L L4 - Flex, 2.5L L4 - Gas, 2.7L V6 - Gas
Ford   Fusion   2016   S, SE, Titanium   1.5L L4 - Gas, 2.0L L4 - Gas, 2.5L L4 - Gas
Ford   Fusion   2015   S, SE, Titanium   1.5L L4 - Gas, 2.0L L4 - Gas, 2.5L L4 - Gas
Ford   Fusion   2014   S, SE, Titanium   1.5L L4 - Gas, 1.6L L4 - Gas, 2.0L L4 - Gas, 2.5L L4 - Gas
Ford   Transit Connect   2017   Titanium, XL, XLT   2.5L L4 - CNG, 2.5L L4 - Gas, 2.5L L4 - LPG
Ford   Transit Connect   2016   Titanium, XL, XLT   2.5L L4 - CNG, 2.5L L4 - Gas, 2.5L L4 - LPG
Ford   Transit Connect   2015   Titanium, XL, XLT   2.5L L4 - CNG, 2.5L L4 - Gas, 2.5L L4 - LPG
Ford   Transit Connect   2014   Titanium, XL, XLT   2.5L L4 - CNG, 2.5L L4 - Gas, 2.5L L4 - LPG
Lincoln   Continental   2017   Black Label, Premiere, Reserve, Select   2.7L V6 - Gas, 3.0L V6 - Gas, 3.7L V6 - Gas
Lincoln   MKC   2017   Black Label, Premiere, Reserve, Select   2.0L L4 - Gas, 2.3L L4 - Gas
Lincoln   MKC   2016   Black Label, Premiere, Reserve, Select   2.0L L4 - Gas, 2.3L L4 - Gas
Lincoln   MKC   2015   Base, Black Label   2.0L L4 - Gas, 2.3L L4 - Gas
Lincoln   MKZ   2017   Black Label, Premiere, Reserve, Select   2.0L L4 - Gas
Lincoln   MKZ   2016   Base, Black Label   2.0L L4 - Gas, 3.7L V6 - Gas
Lincoln   MKZ   2015   Base, Black Label   2.0L L4 - Gas, 3.7L V6 - Gas
Lincoln   MKZ   2014   Base   2.0L L4 - Gas, 3.7L V6 - Gas
* Recent Topics
Re: New Moderator
by ZSHO | Today at 08:05:01 AM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | Today at 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Back to top
