July 08, 2020, 09:09:36 AM
Author Topic: "How-To" Remove (2010-12) SHO Front Bumper.....  (Read 540588 times)
Offline bpd1151
  • Forum Supporters
  • SHOcago S/W 'Burbs
  • -Given: 2429
  • -Received: 2481
  • SHOGAZM
« on: July 05, 2013, 10:59:33 AM »
Here is my write up on "how-to" remove the front bumper clip from your 2010+ Taurus / SHO.
First, compile the following items / tools:
Floor jack and stands (unless you have access to a lift)
Lug wrench (to aid in removing the front tires)
Philips Screwdriver
Flathead Screwdriver (x2)
Pair of pliers
Socket set (you will only be using an 8mm & 10mm socket)
The following items below albeit not "necessary" certainly aid in the process:
Mechanics Creeper
Couple of old bed sheets or cloth (to protect paint on bumper when removed)
Large fan (climate dependant as it was hot as hell by me the day I did this)
Be sure to ice down a few cold ones now so when you're done, you can kick back and revel in your accomplishment(s) while get'n a lil lit
_________________________________________________________________
1st up, work somewhere in the shade, preferably your garage.
Pull your beast in, chock the rear wheels, and then using your floor jack, jack up both sides of the car towards the front end.
Prop your vehicle up using stands, never use your jack for anything other than raising or lowering your car.
Once jacked up, remove both front tires completely.
Next up..... take the time to completely remove both of the inner fender skins from each side of the car.
The skins are held in primarily by plastic pop rivets. I think there are ten (10) of them total, spread out at various points throughout the inner fender.
Now the odd thing about these plastic pop rivets, is they appear that they can just be unscrewed using a philips type screwdriver.... wrong (at least in my experience).
I ended up using two (2) flathead screwedrivers on either side if the center portion itself, just enough to pry each of them outwards a tad bit so I can then use my pliers to grasp the rest of the center portion out.
Once removed, then the semi-larger circular part will easily just fall out.
There's also one 8mm bolt head towards the bottom (in front of each tire respectively) closest to the inside of the car that will need to be removed as well.
I tried to mark most of their locations here using blue painter's tape as a point of reference, but some of the tire shine products I use kept causing the tape to fall off......
One more hiding up top, closest to the shock tower....
Once removed, toss the skin to the side for re-assembly later.
Your wheel well should be exposed and look like this:
Grab your mechanic's creeper and slide your butt under the front end. Looking up, there's a plastic shroud, immediately before (or in front of) the front frame rail. You will see an additional five (5) of these same plastic pop rivets (as located in the fender wells) that are holding this plastic cover in place.
Remove these five (5) plastic pop rivets in the same fashion as described above for the inner fender skins.
Now slide your butt back out from the under side, and proceed to the top part of the engine bay. Positioning yourself over the front of the car, peering into the engine bay, remove the top plastic piece that covers the radiator and intercooler.
There are a total of four (4) 10mm bolts, two (2) plastic pop rivets, and then a total of eight (8) philips screws (screwed into the top of the stock/OEM grille) that will all need to be removed in their entirety in order to remove the piece as required.
Again, I tried my best to mark off each of these fastener's that need to be removed, mainly as a point of reference, but was having difficulty due to the Armor All type products used to dress the engine bay not letting the tape stick.....
Toss the piece to the side so it's available for re-assembly:
Your engine compartment should look like this once removed:
Now go manuever back to the wheel wells as you have essentially just one final step left before you're able to the remove the entire front bumper clip.
Peering into the wheel wells, you'll see on either side of the car, near the seam where the front bumper clip mates to the front upper quarter panel, one solitary remaining philips head screw/fastener.
Removing this screw on either side of the car, is the final remaining fastener:
Now I was able to remove the entire bumper cover myself, however, if you happened to have a second person handy and is willing to help you, then have that person "at the ready" right now.
On either side of the front bumper clip, the clip itself is "seated" on a plastic rail that's stamped into the body frame. That plastic piece looks like this:
You and your partner will need to gently, but with some degree of force mind you, tug and/or pull the bumper clip away from and off of, this plastic rail.
You may hear a minor popping type noise, don't be alarmed.
Once you do this, the entire front clip will dislodge and essentially either fall into your hands (if your prepared for it) or to the ground.
Your front end will now be exposed and should look something like this:
Now because I performed this bumper clip removal mainly for the purpose of installing my custom upper and lower grilles from Mobsteel, in this next shot I took of the backside of the front bumper clip, you will see the stock/OEM grilles removed from the clip:
This is wear those old crappy bed sheets come in handy as you notice I placed the bumper clip face down in order for me to proceed removing the stock grilles.
For those of you that have opted to rock the open mouth mesh upper and lower grilles from Mobsteel, pay particular attention to the small bag of retaining clips that come shipped with your grilles.
I initially had tossed those out (not knowing where they went) and well, on my trip this Summer to visit the boys over at Mobsteel in Michigan, they inspected my work and were perplexed to see minor misalignment issues.
They asked me to pop the hood and then once they peered inside, they asked me where the retaining clips were at?
Not having any type of install guide to go by, my reply to them was: 'I just fk'n tossed those clips out'.
I learned that those retaining clips are supposed to be placed all around the outer edges of the MS grilles and get sandwiched 'tween the grille assembly, as well as the stock portion(s) of the OEM bumper cover.
Below are a couple of pics that demonstrate those supplied retaining clips and their placement are the outer portions of the frames:
____________________________________________________________________________________
This mod can be performed for a variety of reasons, i.e. those desiring to install an aftermarket radiator or intercooler, or in some cases those guys who have installed the meth injection kit(s), or even for those desiring to monkey around with their head assemblies and remove them for tinting (or whatever the case may be).
Either way, the procedures noted above, are all of the steps necessary that need to be taken in order for the front bumper to be removed.
As always (like all of my "how-to" write up's) I do hope that this specific "how-to" is somewhat informative and useful and I appreciate your comments and appreciate even more, taking the brief moment to click on the "thanks" tab as it shows I am contributing in some small way to the community overall.
« Last Edit: November 12, 2017, 04:35:34 PM by ZSHO »
World's Highest AWHP SHO (Aug. 2014 - June 2016) & World's Fastest Ecoboost SHO (Nov. 2015 to July 2019) Details Here: http://www.dragtimes.com/Ford-Taurus-Timeslip-27985.html
Offline bpd1151
  • Forum Supporters
  • -Given: 2429
  • -Received: 2481
  • SHOGAZM
Re: "How-To" Remove (2010-12) SHO Front Bumper.....
« Reply #1 on: July 05, 2013, 11:03:59 AM »
If there may be questions from any of you along the way, let me know, either via PM, or simply posting here. For those of you that may be tackling this project yourself, for w/e the reasons may be and you need immediate assistance, give me a heads up on your planned install date and I'll PM you my cell for emergency use only if questions should arise.
Otherwise, this write up in and of itself, should be pretty self explanatory.
Oh yea, one last thing, obviously it goes w/o saying that you need to simply "reverse" the steps above for re-assembly, however, as I found out, you will definitely need that second person to aid you in aligning the bumper cover back onto those plastic rails prior to re-attaching all of the fastener's.
Good luck and here's a nice pic of the final results:
As well as a group pic of the boys from Mobsteel fame that gave me the 'ol proverbial stamp of approval upon leaving their facility.....
« Last Edit: November 12, 2017, 04:39:45 PM by ZSHO »
Offline bpd1151
  • Forum Supporters
  • -Given: 2429
  • -Received: 2481
  • SHOGAZM
« Reply #2 on: July 05, 2013, 11:11:28 AM »
**Update 07/05/13**
This is my "How-To" I wrote up from back in 2011. I wanted to post this hear on EBPF for all of my fellow EcoBoost SHO owners to benefit from.....
It is important to note, that as of Spring of 2013, Mobsteel is no longer producing the grilles depicted in this post.
Just like other companies that have been affected by the economic downturn, the vendor they used for fiberglass work, went defunct.
Mobsteel tried, albeit in vain, to locate another fiberglasser, but were not impressed with the quality of some of the new vendors they were researching.
As of now, I believe that Mobsteel has sold the molds for these grilles to another well known company called Tommy Z.
Mad props though to Mobsteel owner Adam Genei, and all of his wonderful staff for having put up with all of my endless emails, phone calls, and other forms of badgering, in order to produce these grilles in the first place.
I could never thank them enough for all of their talents and any of you interested in other types of mods, no matter the platform, no matter the model year of your ride.....
Please be sure to check out Mobsteel and give them a shout.
http://www.mobsteel.com/
Thanks y'all......  :thankyou:
Mike  :beer:
Offline ECOBOOST
  • Newbie
  • -Given: 0
  • -Received: 0
« Reply #3 on: September 20, 2013, 07:32:04 PM »
Had to dig this thread up to ask what you used to paint your "side scoops (?)" that shiny chrome black color?  I really like the look of them.
Matte black plastidip color sprayed over the chrome was less than flattering....  :no:
Offline bpd1151
  • Forum Supporters
  • -Given: 2429
  • -Received: 2481
  • SHOGAZM
« Reply #4 on: September 20, 2013, 07:40:03 PM »
Are you referring to the faux, non operational side vents?
If so, those were professionally painted & hand lettered by my wonderfully talented body shop pals.
Sent from my DROID3 using Tapatalk 6
Offline n8rfastback
  • Full Member
  • -Given: 0
  • -Received: 1
« Reply #5 on: September 20, 2013, 08:29:16 PM »
Great how to!
2010 SHO
Offline ECOBOOST
  • Newbie
  • -Given: 0
  • -Received: 0
« Reply #6 on: September 23, 2013, 07:45:37 PM »
Yes..I really didn't know what to call them.
Thanks for the reply...thinking about using some gloss plasti-dip or some tinted clear coat over the chrome to try and get a similar look.
Offline BlueSHO
  • Crete, ILliNoIS
  • -Given: 123
  • -Received: 107
« Reply #7 on: March 04, 2016, 12:20:25 PM »
Awesome write up.
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline Linemonkey
  • Full Member
  • Seminole, Tx
  • -Given: 108
  • -Received: 38
« Reply #8 on: April 17, 2017, 01:50:44 PM »
Does anyone know if this procedure is any different for the '13+ models?
Sent from my SAMSUNG-SM-G930A using Tapatalk
2013 SHO PP Tuxedo Black
3 bar
160 T-STAT
Catless DPs
Tune by AJP
Offline Jeremy S.
  • Newbie
  • -Given: 0
  • -Received: 6
« Reply #9 on: May 18, 2017, 01:33:39 PM »
Great write up with lots of pictures and tips.  I took my front bumper off last night and was able to do it with the car on the ground; no jack stands, removing wheels etc.. you just need to turn the steering wheel towards whichever side you aren't working on.  It is not necessary to completely remove the splash guards from the wheel wells which will save you a lot of time.  On each side there are 3 screws, an 8mm bolt and a screw headed push rivet that need to come out that attach the splash guard to the bumper.  Then follow the same instructions as above to detach the bumper from the radiator shield and the front wind deflector shield underneath.  Also disconnect the fog light plugs on either side.  Total process takes about 15 minutes to remove and another 15min to put back on.  -Jeremy
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1935
  • -Received: 4070
« Reply #10 on: November 12, 2017, 10:47:28 AM »
Some mighty Purdy Pic's above. Z  :)
« Last Edit: November 12, 2017, 11:02:16 AM by ZSHO »
* Recent Topics
Re: SM105K's Ownership/Performance/Maintenance Thread
by bpd1151 | Today at 07:59:38 AM
113 degree weather my trans got to roughly 205 degrees. Ambient air te...
by 10sleeper | Today at 01:04:53 AM
Very nice! Should have mine on in a couple days....
Re: SHOdded Officially Retiring as Admin
by FearlessAZ | Today at 12:36:54 AM
Need to just catalog all of his posts to make into an ecoboost encyclo...
by bpd1151 | July 07, 2020, 10:46:47 PM
That doggone BPD guy shattered my build tho lol.Sorry......Sent from ...
by 802SHO | July 07, 2020, 09:29:20 PM
I have never seen 32mpg.. good for you!I see like 14 mpg lol!  Bu...
Re: Has anyone install custom Hood?
by sm105k | July 07, 2020, 11:07:33 AM
Ford Derrick is the owner, I pinged him back in May of last year.. att...
Re: Phenolic Spacers
by 802SHO | July 07, 2020, 09:43:41 AM
Nevermind, purchased some from my local O'Reillys for $54Sent fro...
Re: AO tune vs downpipes
by StealBlueSho | July 07, 2020, 09:37:30 AM
Matt R. said I didn't need a revision for my catted PPE's on...
Re: TASCA=Fail....
by SilvererSHO | July 06, 2020, 09:41:25 PM
And to confuse things even more, here's the listing for a 2013 SH...
Re: Edge ST .......Here she is
by Macgyver | July 06, 2020, 07:19:10 PM
I really like it.  How is the room?  Maybe one of those will...
Back to top
