Started by 92BlackGT, August 29, 2015, 03:59:31 AM
Quote from: ZSHO on November 03, 2016, 10:29:43 PMWelcome aboard Coop6 and here is a useful diagram on the rear springs. Z https://drive.google.com/file/d/1u3aNz_Uo3BWKp8gsZYLJKRUkD9Ziw_xwShgX85Jp9OziPRIN81ckWFVgikaBlwYvspZB-TccNmGMMd5L/view?usp=sharing
Quote from: coop6 on November 20, 2016, 07:36:37 PMQuote from: ZSHO on November 03, 2016, 10:29:43 PMWelcome aboard Coop6 and here is a useful diagram on the rear springs. Z https://drive.google.com/file/d/1u3aNz_Uo3BWKp8gsZYLJKRUkD9Ziw_xwShgX85Jp9OziPRIN81ckWFVgikaBlwYvspZB-TccNmGMMd5L/view?usp=sharingThanks for that info! If I'd like the rear almost level, maybe 1/4" higher, how much coil should be cut?Has anyone cut a little of the front coil with success? I just don't want to ruin the ride quality. I just don't want to go as low as the hr springs.
Quote from: polskifacet on June 30, 2017, 10:16:20 AMDid this yesterday. Was easy. Needs camber adjustment bolts. There is a little spring droop which means that at full extension, the spring is a bit loose compared to stock.
Quote from: polskifacet on June 30, 2017, 01:13:42 PMDoes anyone know if H&R springs are a smidge loose in the seat? Wondering about safety when jumping rail road tracks lol.
Quote from: Heelfan1 on June 30, 2017, 08:38:56 PMQuote from: polskifacet on June 30, 2017, 01:13:42 PMDoes anyone know if H&R springs are a smidge loose in the seat? Wondering about safety when jumping rail road tracks lol.The rear H&R spring out of the car are not much if any shorter than the stock spring. When installing mine I put them side by side and was surprised how close the height was. Visually just sitting on the garage floor you couldn't tell the difference in height.
