September 18, 2021, 12:30:29 AM
Author Topic:  PID for PTU Temperature  (Read 14023 times)
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1945
  • -Received: 4088
  • Liked:
  • Likes Given: 0
Re: PID for PTU Temperature
« Reply #15 on: June 25, 2017, 06:37:18 PM »
What temps are you guys seeing? ive seen mine as high as 190 on a hot day... cools down on idle.. (13 pp sho)
It sounds about right!! Under extreme temperatures/conditions of high Torque would be around 195 deg F.  Z
« Last Edit: June 25, 2017, 06:46:49 PM by ZSHO »
Offline craigtone
  • Jr. Member
  • Holland, MI
  • Thank You
  • -Given: 2
  • -Received: 3
  • RAGNBUL
  • Liked:
  • Likes Given: 1
« Reply #16 on: June 06, 2021, 11:46:12 AM »
Sorry to dig up an old thread but I am planning to install the PI PTU on my 2013 non-PP SHO.  Did anyone ever find out if the non-PP harness has provisions for the PTU temp sensor?  Also, would I need a PI PCM in order to get the code that monitors service intervals for the PTU fluid?
Option B is just add a trans temp gauge with a generic oil temp sensor in the factory temp sensor port and manually monitor temps.
2015 SHO (non-PP) - Off-Road DPs, K&N Intake, Dynomax Mufflers, Ortiz Tune, Aux Trans Cooler, H&R Springs, PP Shocks, PI Brakes, ScanGauge 2, Mobil1 HM
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 100
  • -Received: 388
  • Ecobooster
  • Liked:
  • Likes Given: 28
« Reply #17 on: June 06, 2021, 04:24:22 PM »
Old threads are very informative. Its good to revive them.
