July 05, 2020, 06:39:51 AM
Author Topic: Random thoughts for the day  (Read 1862597 times)
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1935
  • -Received: 4069
Re: Random thoughts for the day
« Reply #3990 on: May 23, 2020, 05:29:58 PM »
New video from (FTM) on the latest Taurus/Explorer Recall 19S17 & 20SO4 on Rear Toe link failure and what to expect!
I hope everyone is doing well. Z  :)
Most excellent post Z, everyone should give this a watch.
Thanks Brother! Definitely a must watch for any SHO/Explorer owner.
Here are a couple great informative threads. Z
https://www.ecoboostperformanceforum.com/index.php?topic=7650.msg115836#msg115836
http://www.ecoboostperformanceforum.com/index.php/topic,7087.msg115835.html#msg115835
http://www.ecoboostperformanceforum.com/index.php/topic,7536.msg115013.html#msg115013
Ford -Lateral Link
https://www.tascaparts.com/oem-parts/ford-lateral-link-de9z5a972c
« Last Edit: May 23, 2020, 05:37:42 PM by ZSHO »
Offline StealBlueSHO
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2636
  • -Received: 2690
  • I poke at BPD1151
« Reply #3991 on: June 06, 2020, 12:14:41 PM »
Tired of tires...... running out of room due to car parts.... and these are not helping...
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 95
  • -Received: 317
  • Ecobooster
« Reply #3992 on: June 06, 2020, 05:29:27 PM »
I have 3 stacks of 4.......
« Last Edit: June 06, 2020, 05:31:52 PM by Macgyver »
Offline bamsho
  • Elite Member
  • south williamsport, pa
  • Thank You
  • -Given: 184
  • -Received: 489
  • Ecobooster
« Reply #3993 on: June 08, 2020, 06:37:50 PM »
Well the family took on the task if redoing our deck this past weekend.   We replaced the old pressure treated flooring with Trex.  Also colored stained the rails are well as replaced some bad supports.  First time using Trex, it actually went better than expected.  Also found out by accident that only the 12ft and 16ft boards have the slots cut for there hidden fasteners.  So here are some before and after pics.
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2636
  • -Received: 2690
  • I poke at BPD1151
« Reply #3994 on: June 09, 2020, 10:46:37 AM »
Going for the record!!!
* Recent Topics
Re: Edge ST .......Here she is
by Macgyver | Today at 12:21:26 AM
Sharp!!!!! Sent from my SM-N950U using TapatalkThank You sir.She is no...
Re: Traded in the SHO.......
by Macgyver | July 04, 2020, 11:05:20 PM
Finally Done. Had to go to a different dealer as the original dealer r...
Re: New Moderator
by sm105k | July 04, 2020, 02:31:56 PM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | July 04, 2020, 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Back to top
