July 04, 2020, 11:49:17 AM
Author Topic: Oil Analysis Reports  (Read 27643 times)
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 95
  • -Received: 315
  • Ecobooster
Re: Oil Analysis Reports
« Reply #30 on: October 21, 2018, 02:21:08 PM »
Not one for stretching OCI. 8500 miles? Nope. 3500 and no more for me. $30 bucks. But I can understand people that drive a lot of miles for 3500 to be unreasonable.
Offline mjhpadi
  • Elite Member
  • Lewisburg, PA
  • Thank You
  • -Given: 341
  • -Received: 282
  • PADI IDC Instructor #17746
« Reply #31 on: October 24, 2018, 10:24:34 AM »
Blackstone Labs told me I was wasting money changing my Royal Purple at 3K intervals after they tested my used oil, so now I go to 4500 miles between changes.  Having Blackstone test my used oil was well worth the 25 bucks it cost.
Offline 6500rpm
  • Quality Always Shoots Straight
  • Full Member
  • the safe zone just outside St Louis
  • Thank You
  • -Given: 45
  • -Received: 100
  • Ecobooster
« Reply #32 on: October 24, 2018, 08:12:38 PM »
I look at the reports more like a watchdog than a reason to stretch my intervals. I average 15-18k miles a year and typically try to change oil every 5-6k miles. It's good to be able to look at data once or twice a year and quantify things like fuel dilution, solids, and water in the system to use as indicators to see if antifreeze or excessive fuel  is starting to enter the system. Also how well the filters are functioning to keep the abrasives at bay.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes
Offline Sbouvia
  • Full Member
  • Alexandria, VA
  • Thank You
  • -Given: 39
  • -Received: 58
  • Ecobooster
« Reply #33 on: January 20, 2019, 09:24:36 PM »
Latest oil analysis for SHO attached. Mostly city driving but a few long trips. Also attached is latest Jeep one so you can see that Blackstone is helpful when issues arise. Jeep seems to have a head gasket or worse going on. Jane the Jeep is going to go under the knife soon for lots of old part changes.
~Scott
2013 SHO non-pp. Powerstop Top Cop kit brakes, 3bar map sensor, 93 octane 3bar AJPTurbo tuned.
2002 Jeep Wrangler TJ (Jane) w/ 2.5" lift, banks torque tubes, monster exhaust and intake, whole new top end of motor after head gasket repair
1991 F Super Duty 2.5 ton dump truck w/ 7.3IDI
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #34 on: January 20, 2019, 09:49:42 PM »
Yeah the Amsoil is done for.  U use the Amsoil filter?  City driving dumps fuel into the oil, but watch for a trend - injector.
On the jeep:  same oil- castrol hm - the entire time?  Very little antiwear additive.  Seems to be a coolant leak 4 sure.
Offline Sbouvia
  • Full Member
  • Alexandria, VA
  • Thank You
  • -Given: 39
  • -Received: 58
  • Ecobooster
« Reply #35 on: January 21, 2019, 08:28:02 PM »
Yea I have been using the amsoil filter. I may go back to motorcraft soon. My amsoil guy here keeps filters on hand for me essentially as his other clients donít use that filter. Iíll keep look out for fuel in oil, at least injectors look easy to swap on this motor.  Unfortunately there will be quite a bit of city driving until jeep is fixed, we put some mileage on the car. F Super Duty doesnít fit so well in Old Town Alexandria.
Yea I have been using the the castrol hm for a while now on the Jeep. I started using it after I noticed issues with the possible coolant. I tried Mobil 1 at one time in Jeep but that was only for a 3,000 mile oil change.
Straight up amsoil in everything now besides Jeep differentials and transfer case.
~Scott
Offline 802SHO
  • Elite Member
  • Essex Junction Vermont
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
« Reply #36 on: February 01, 2020, 06:01:27 AM »
Just in.  The Blackstone Laboratories test results of my RDU fluid.  Sample was before my last track outing of the season in October 2019.  Its a low mileage sample of almost 2000 miles of "severe duty".  I will use this test result as my baseline moving forward.
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #37 on: February 01, 2020, 08:16:32 AM »
This the first time you used LWSP?  I would not use as a baseline if so, because that high detergency will clean off / out the gunk clinging to the gears and the inside of the case.  Hopefully the next test will show significantly improved numbers.
If it is not the first change, then there might be something to look into.  If you are up to it, take the diff cover off and take a good look inside.
Offline 802SHO
  • Elite Member
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
« Reply #38 on: February 01, 2020, 09:35:43 AM »
Interesting.  In the last 5k miles (Since April 2018) I have changed the fluid 3 times.  Before that I don't know if it was ever changed before.  Mileage was about 69k when I changed it the first time.  I used Royal Purple 75w90.
Changed again in 3k for the first time with RLWSP.  Then drove about 2k more, changed again.  This sample is what came out after that low mileage duration first using RLWSP.  I think the next test will be perhaps a better baseline.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #39 on: February 02, 2020, 12:34:19 AM »
Fingers crossed :)
Offline 802SHO
  • Elite Member
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
« Reply #40 on: February 05, 2020, 08:30:41 AM »
PTU results of same interval ..about 2k miles and same fluid, Redline Lightweight Shockproof gear oil.  Glad I changed it out.  I'll be tapping the PTU to add a drain plug, so I can do a proper flush and rule out left over wear-in from contaminating the rest results.  Confident to see better results next time.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #41 on: February 05, 2020, 10:24:05 AM »
Did you happen to take pics of the Redline after sampling, and if so, after letting it sit a few hours or more?
This is a comparison of virgin to used product (PTU) 6 months/5K later from my 2007 Edge.  There was some slurry at the bottom of the used fluid.  IDK if the labs shake up the samples before analysis, I assume they do.
« Last Edit: February 05, 2020, 10:26:26 AM by SHOdded »
Offline 802SHO
  • Elite Member
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
« Reply #42 on: February 07, 2020, 06:47:14 AM »
PTU fluid from sample.  Not bright green anymore that's for sure
Offline 802SHO
  • Elite Member
  • Thank You
  • -Given: 2177
  • -Received: 1047
  • Boosted
« Reply #43 on: February 07, 2020, 06:48:54 AM »
Blackstone Laboratories PTU Test Results.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #44 on: February 07, 2020, 08:37:09 AM »
Fingers crossed, next result will be much better.  How does it feel drivingwise tho.  With Severe Gear and LWSP in my Edge, I felt almost as if the AWD were absent, in a good way.  Climbing hills at speed is effortless.
* Recent Topics
Re: New Moderator
by ZSHO | Today at 08:05:01 AM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | Today at 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Back to top
