July 04, 2020, 10:56:49 AM
Author Topic: Oil Analysis Reports  (Read 27642 times)
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Last Edit: February 07, 2016, 07:47:06 AM by FoMoCoSHO »
Offline BlackJac
  • Full Member
  • New Jersey
  • Thank You
  • -Given: 2
  • -Received: 29
  • Ecobooster
Re: Blackstone Laboratories Reports
« Reply #1 on: March 20, 2015, 12:27:39 PM »
Is it better to wait until after the first oil change/ break-in period to have the oil tested, say second oil change ?
2017 Fusion Sport - 401A/ Moonroof/ Magnetic Grey/ Livernois Motorsports 93 Stage 3
2015 Explorer Sport  - SOLD
Modded 1980 Corvette
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13013
  • -Received: 4215
« Reply #2 on: March 20, 2015, 01:47:45 PM »
I don't believe there is any set time to start the analysis.  I'd think the second oil change would be a good point to start, for ongoing purposes.
Offline jbeez
  • Full Member
  • Bristol TWP, PA
  • Thank You
  • -Given: 188
  • -Received: 43
  • Ecobooster
« Reply #3 on: December 28, 2015, 12:14:30 PM »
Has anyone changed oil change interval or type of oil they use based on analysis so far? How about filters?
What is current best practice for engine oil and ptu?
2014 PP SHO Darkside Metallic
K&N Panel filter, 3bar map, AJPTurbo tune, Motorcraft SP542 @.28, MSD Coils, PPE Catted downpipes, EBP Hot pipes w/ tial BOV, Tracy Lewis catch can, 170 tstat, 93 octane pump gas
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1935
  • -Received: 4069
« Reply #4 on: December 28, 2015, 12:33:06 PM »
The Motorcraft FL-500S oil filter is clearly the best choice in my opinion,and Amsoil 75w-140 for the PTU UNIT and 80w-90 for the RDU gear oil is no doubt the best in the market,had mine changed at 33k which the ocd in me is to blame,probably could of waited a little longer,Amsoil,Redline,Penzoil ultra motor oil changed at a 5k interval seems more than adequate.  Z
« Last Edit: December 28, 2015, 12:47:55 PM by ZSHO »
Offline panther427
  • Elite Member
  • Thank You
  • -Given: 55
  • -Received: 107
  • booooost
« Reply #5 on: December 28, 2015, 05:32:21 PM »
Here is my black stone report
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 700
  • -Received: 1157
  • The Tenth Man
Re: Oil Analysis Reports
« Reply #6 on: February 13, 2016, 08:16:21 PM »
That confuses me, they say the high iron could be due to higher than avg interval, then tell you to increase it?
Offline panther427
  • Elite Member
  • Thank You
  • -Given: 55
  • -Received: 107
  • booooost
« Reply #7 on: February 13, 2016, 08:27:33 PM »
Ya lol i was a bit confussed on that too.. Other than the fact i had enough TBN to run the oil longer.  The car was tunned the entire run of oil and had several drag strip passes. Plus my driving style is aggressive.. Either way im not to worried about 54PPM based on 1 snapshot.
Offline sholxgt
  • Elite Member
  • Thank You
  • -Given: 27
  • -Received: 271
  • Ecobooster
« Reply #8 on: November 14, 2016, 06:06:55 PM »
Oil Report on Full Synthetic Motorcraft 5w/30 run for 6,000 miles.
Please chime in and let me know what you think.  My only comment is it appears that 5,000 miles is probably a better interval due to the thin viscosity.  My guess on the fuel dilution is that it's due to me idling at my son's bus stop?  I cold start the car and drive it one mile each day and then it idles for about 10 minutes before I pick him up and run errands.
« Last Edit: March 28, 2018, 06:33:03 PM by SHOdded »
Offline AJP turbo
  • SCT dealer and custom calibrator 3.5 ecoboost specialist
  • Vendor
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
« Reply #9 on: November 14, 2016, 06:50:15 PM »
Im not sure its fuel dilution...ive seen reports that shows motorcraft oil shearing badly...im questioning the issue of fuel dilution in these and other DI motors...they run leaner at wot and command enrichment later and the fuel spends less time in the cylinder on top of that because its di and the fuel is sprayed late on the compression stroke rather that early in the intake stroke...so a full stroke later
Offline sholxgt
  • Elite Member
  • Thank You
  • -Given: 27
  • -Received: 271
  • Ecobooster
« Reply #10 on: November 14, 2016, 07:03:38 PM »
I'm no expert, but they measured fuel at nearly 2%.  Wouldn't that be fuel dilution?  I don't buy the lean burning part of DI given that my DI and my Dad's both soot the crap out of the tailpipes.  I know that's not a scientific measurement, but... My tailpipes look dirtier than the 4" pipe that was on my diesel SuperDuty that rolled coal.
I also live in the country with 55mph speed limits and very few stop lights and only average 20mpg.  Same I got with the SuperDuty or my old school v8 CrownVic.  The MKS has decent power, but overall if this is an example of DI...they can keep it!
« Last Edit: November 14, 2016, 07:06:42 PM by sholxgt »
Offline AJP turbo
  • Vendor
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
« Reply #11 on: November 14, 2016, 07:07:52 PM »
Pipes may be dirty and i cant tell you why but di motors have less fuel delivered all things being equal...that was one of the benefits and reasons they use less fuel at wot...there is no fuel laden air mixture during the compression stroke so there should be less chance for preignition because there is no fuel present
The crown vic is grossly outperformed in every measurable aspect so if economy is similar that is great accomplishment and diesels are a different animal that uses fuel with much greater energy so apples to well, watermelon
I think the crown vic might run better with an escape with the 2.0....power is about the same lol
« Last Edit: November 14, 2016, 07:12:27 PM by AJP turbo »
Offline BlueSHO
  • Elite Member
  • Crete, ILliNoIS
  • Thank You
  • -Given: 123
  • -Received: 107
  • Ecobooster
« Reply #12 on: November 14, 2016, 07:09:25 PM »
Don't the results show a trace of fuel? Where's the 2% coming from? Maybe I'm not reading that right.
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline sholxgt
  • Elite Member
  • Thank You
  • -Given: 27
  • -Received: 271
  • Ecobooster
« Reply #13 on: November 14, 2016, 07:11:59 PM »
Thanks Steal!  I was reading it wrong.  Not you.  Trace definitely doesn't mean full dilution.
AJP is probably right about the oil shearing.  That would make sense given the results.  Doesn't look to be enough of a problem given the miles accumulated though.
Curious, has anyone done a test on Amsoil Signature in our platform with a full term interval?
I have Mobil 1 Extended Performance in now and will test it to compare.
Offline BlueSHO
  • Elite Member
  • Crete, ILliNoIS
  • Thank You
  • -Given: 123
  • -Received: 107
  • Ecobooster
« Reply #14 on: November 14, 2016, 07:14:11 PM »
Steal?  Blue here as in Blue Jeans
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
* Recent Topics
Re: New Moderator
by ZSHO | Today at 08:05:01 AM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | Today at 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Back to top
