February 27, 2020, 07:48:29 PM
Author Topic: "How-To" 5000K Switchbacks and sidemarkers installed! - ShoBoat  (Read 635661 times)
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Gilbert - SE Phoenix Metro Area
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
Re: "How-To" 5000K Switchbacks and sidemarkers installed! - ShoBoat
« Reply #15 on: January 29, 2014, 08:51:21 AM »
In My post on the vLEDS there are a couple of pics on ballast mounting.  I actually used an existing screw on top of the wheel well on the right... should work... the link is a couple of posts back.
If you can't get into the headlight cowl to install the HIDs from the engine compartment you may have to remove the bumper... here's how: http://www.ecoboostperformanceforum.com/index.php?topic=521.msg3154#msg3154
Either way there is a bit of R&R to do
Here is a link to the post by dalum with headlight wiring diagrams:
http://www.ecoboostperformanceforum.com/index.php?topic=1730.15
Hope this helps... just go slow and don't get frustrated
Offline abnjeffy
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #16 on: January 30, 2014, 05:01:07 AM »
Do I need to do any actual wiring or splicing with the HID kit?  I thought it was plug and play?
---2013 Taurus Limited, non-SHO---
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
« Reply #17 on: January 30, 2014, 07:14:26 AM »
I don't have your kit... but you'll have to get power from your HL switch some where... so you'll at least need to find them and a plug..... I'd call the manufacturer of your HIDs and ask. I didn't do HIDs as the 2013 SHO comes with them.. Here's a link to the wiring diagrams dalum posted... http://www.ecoboostperformanceforum.com/index.php?topic=1730.msg22778#msg22778
Offline SwampRat
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Tulsa, OK
  • Thank You
  • -Given: 314
  • -Received: 197
  • 2013 SHO SHONUFFBOOSTED
« Reply #18 on: January 30, 2014, 08:13:01 AM »
I Highly suggest that  With an aftermarket HID Kit That you use  a Relay Harness So POWER comes straight from the Battery ..
VLEDS sells one for the Kit you want ... http://www.vleds.com/morimoto-9006-hb4-relay-harness.html
The factory wiring on none HID Models is usually to Small for the extra amperage demands of HID's
SO NO they are Not plug and Play ..
Not hard to do ... take your time and don't try to rush it
On My 2011 Fusion Sport I Installed  a HID Kit  . I would install the Ballast's  Behind the Lower Bumper area away from the Elements  . It is Fairly easy to remove The Plastic Shroud below the front of the car  . I did this when I put my lower Billet Grill on my 13 SHO.
2012 AWD EDGE Sport ... Kona Blue
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 12530
  • -Received: 4118
« Reply #19 on: January 30, 2014, 12:28:32 PM »
What was the wattage on the HID system?  I know on our Edges, 35W is fine hooking directly into the factory harness, but 55W definitely needs to be hooked up directly to battery.  Ballasts can take up to 2x the amount of power to fire (think fluorescents), so a 35W could possibly take up to 70W and a 55W could require up to 110W momentary power to fire.
Offline abnjeffy
  • Jr. Member
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #20 on: January 30, 2014, 12:31:36 PM »
I bought that relay harness with the HIDs, which may be adding to why I am so overwhelmed with all this wiring I am staring at
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
« Reply #21 on: January 30, 2014, 12:45:57 PM »
Don't let the diagrams and wires confuse you. Determine what attaches to what.  Then locate these point in the car and on the harness. Next locate the physical areas in the car.  Now you know how to connect it.  Finally consider how to route the wires and when you're satisfied begin the install.
If you are worried you can't do it correctly and the vLED folks can't clarify it for you I'd recommend getting a professional.  All of us do from time to time as we mod.
Offline ShoBoat
  • Elite Member
  • : Canada
  • Thank You
  • -Given: 93
  • -Received: 257
  • Ecobooster
« Reply #22 on: March 05, 2014, 06:34:07 PM »
Hey Guys, I would like to apologize. I realize that a few of you had sent me some questions regarding this mod. I have been otherwise occupied as of late. The V3's are the way to go, I installed these in mine about a month ago. With any SHO that has the DRL active you can reprogram the ECU to activate the turn signals instead of the headlights. This is cool in itself. But the V3's change to from amber to white when this happens. so your DRL turn signals are now white until the signal is pulsed by the indicator stalk. How cool is that! BTW BIGMac nice ride!
2012 Pearl White CTS-V Stock
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
« Reply #23 on: March 05, 2014, 07:00:49 PM »
Thanks ShoBoat! .... I Agree on the signals... VLED is the way to go. Here's a link to the install and a demo video of them working... compares OEM to VLEDs.  some where lse I posted the content of the package... just be sure to get the Ford adaptor!
http://www.ecoboostperformanceforum.com/index.php?topic=1730.msg22650#msg22650
Offline dalum
  • Sr. Member
  • : Central Ohio
  • Thank You
  • -Given: 15
  • -Received: 39
  • All SHO and All GO
« Reply #24 on: March 05, 2014, 11:49:42 PM »
I'm still having problems with mine after trying the new model ford adapters.  Its been so damn cold I haven't felt like messing with them any further yet.
2013 Non-PP SHO
Offline ShoBoat
  • Elite Member
  • : Canada
  • Thank You
  • -Given: 93
  • -Received: 257
  • Ecobooster
« Reply #25 on: March 06, 2014, 07:30:40 AM »
Can you be specific on the issues? I had a few also maybe I can help you out.
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
« Reply #26 on: March 06, 2014, 07:38:36 AM »
Same here... what exactly is it doing? I am having no issues.
I know you purchased before the adaptor was available and got it later
Offline SwampRat
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • : Tulsa, OK
  • Thank You
  • -Given: 314
  • -Received: 197
« Reply #27 on: March 06, 2014, 08:34:40 AM »
My guess is that you need to check the pins inside of the waterproof sockets were the harness plugs into the power brick or extension . One of the pins in the socket was pushed back some and was not connecting on mine.
I pulled it out with needle nose pliers and then put a drop of super glue on the back side of the pin wher the wire comes out of the socket but behind the round colored grommet ..
 It drove me nuts till I figured it out and I had actually forgot about it .
Unplug all of them and visually check that the pins are not pushed in.
Offline dalum
  • Sr. Member
  • : Central Ohio
  • Thank You
  • -Given: 15
  • -Received: 39
It's not immediate or every time now but they will still switch to hyper flash and disable the output until I turn the signal off and back on again.
1: signal, normal flashing a few times, hyper flash with output disabled (switches back to white instead of hyper flash amber)
2: signal, instant hyper flash with stead white again.
I even tried it without the resistor and it still does it which confused the hell out of me.
I need to get forscan hooked back up and see exactly what error the bcm is setting.  I presume it's disabling the output on what it thinks is a high load. It also seems to be worse with the engine running at alternator voltage instead of battery voltage.
2013 Non-PP SHO
Offline BiGMaC
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Thank You
  • -Given: 1155
  • -Received: 705
  • Ecobooster
« Reply #29 on: March 06, 2014, 04:03:42 PM »
It sounds like a defective control unit.  Hopefully it's still in warranty.  Maybe give them a call and see.  I found them very helpful.
* Featured Topics
* Recent Topics
Re: Misfiring codes P0300, P0302 and P0306
by SHOdded | Today at 06:52:07 PM
Awesome!...
Meth nozzle not flush
by ChrisxHowe | Today at 03:06:59 PM
Before I get this bung welded on my hot pipes I test fitted the nozzle...
by SuperPete | Today at 06:11:24 AM
We will find out, please keep up posted, lots of pic's.....
Re: PTP Turbo blanket update for the SHO
by 802SHO | February 26, 2020, 06:25:07 PM
For those waiting on an update of the PTP turbo blankets they are read...
Re: Suggestions where to buy PPE catted DPs
by 10ECOMKS | February 26, 2020, 05:29:52 PM
I just bought a pair of Catted PPE DP's from Vivid Racing for ano...
Re: Battery charge?
by Gjkrisa | February 26, 2020, 08:46:26 AM
I remember seeing something on the cables that looked like a permanent...
Re: SuperPete SHO Build record
by SuperPete | February 25, 2020, 09:19:48 PM
Another video,1/4 mile Dragy showed 12.4 seconds, need to shave anothe...
by bamsho | February 25, 2020, 06:03:27 PM
That's a pretty box, glad I know what's in it, hehe...
Re: 2014 Lincoln MKS EcoBoost with all the goodies $12,900.
by SHOdded | February 25, 2020, 04:38:20 PM
Well, at least you get to move forward!  Good luck with your new ...
Re: Note to self-beware of Tesla
by sm105k | February 25, 2020, 07:03:56 AM
Yep I only have one L in the street light to street light Grand Prix s...
Re: Wrapping intake pipe, numbers are out<<<
by Davidsiebert2 | February 25, 2020, 06:15:54 AM
@SuperPete That’s because the wrap you used doesn’t do much for a radi...
Re: Xdi hpfp
by ChrisxHowe | February 25, 2020, 02:36:03 AM
https://m.facebook.com/groups/823281341395712?view=permalink&id=12...
Are You Organizing a Car Show or Other Auto Related Event?
by RockAuto | February 24, 2020, 12:33:40 PM
RockAuto would love to work with your upcoming car show, cruise-in, sw...
Re: PTU, what's inside and why my 26K mi put took a dump
by SHOdded | February 24, 2020, 12:24:17 PM
the dealer will send you the latest revision even if not so listed on ...
Re: Mustang 5.0
by SHOdded | February 23, 2020, 02:02:09 PM
Hope the dentist is a good one!...
Back to top
