I was looking around the 'net and found this short blurb on how wideband sensors work:
http://www.koiautoparts.com/professionals/articles/032811_wideband_02_sensors.pdfNeed to dig up info on the Ford-OEM WB sensor reference voltages. But from my understanding, the lower the voltage compared to the reference voltage the PCM sends, the richer the A/F mix, and vice versa. Conventional O2 sensors usually range 0.1 to 0.9V, with 0.45V or so being stoich.
The intake manifold pressure is likely "absolute" pressure, and you would subtract 14.7 to get vacuum/boost pressure. That still would mean your SHO is hitting 15 psi or so of max boost. Seems a bit high for a stock tune, and esp so with a 2 bar MAP. A 3 bar MAP would give you more accurate data at that boost level, but then you'd need a tune to go with.
Are you using Torque, or Torque Pro? Strange it would not give you a PID for Bank 2 Sensor 1 O2.
