July 04, 2020, 06:18:36 PM
Author Topic: "How-To" SHO and Flex convert to vent to atmosphere with factory blow off valves  (Read 742187 times)
Offline EcoPowerParts
  • How can I help you today?
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
I just converted my factory BoV to FTA on my Flex today.
What does this do for you?
Nothing but making a PFFFFT noise when you lift the throttle under boost.
Is there any downsides to this?
No, the car is speed desnsity so releasing the air from the turbos to atmosphere when the blow off valves open does not negatively impact the tune, factory or modified.
BTW, I couldn't find 1" vacuum "nipples" to block off the factory tubing so I went to Home Depot and searched around, found some 1" rubber chair leg "tips" to use, worked pretty good so far.
Front Blow off Valve and blocked off tube
Another shot of the factory Blow off Valve with the return tube removed - vent to atmosphere
Close up of rear portion of intake tubing with blow off valve return hose removed and blocked off. For me easiest way to get to this area and remove tubing was to remove the intake tubing and rotate to access the clamp that held the tubing onto the blow off valve.
Rear Blow off Valve
Complete turbo to intercooler pipe with Blow off Valves circled
EDIT: Found some rubber caps to use instead of rubber chair leg bottoms
http://www.mcmaster.com/#92805K28
Updated pictures with the new caps on from mcmaster - didn't know they were going to be red :(
« Last Edit: July 14, 2013, 12:58:42 PM by 4DRHTRD »
Offline PopolZ
  • Full Member
  • Saint-Hubert, Qc - Peoples Republic of Canuckistan
  • Thank You
  • -Given: 6
  • -Received: 10
  • Ecobooster & RB26ster
On the SHO we already have the PFFFFT because of the "noise generator". Mine is sitting in the trunk since it's been replaced with an HKS SSQV III BOV.
2010 Ford Taurus SHO, non-PP, Steel Blue #243 of 301 - Custom tune by Torrie@Unleashed, PPE non-catted downpipes, custom 3rd cat & resonator delete, water/meth injection, HKS SSQV3 BOV and Carbotech AX6 brake pads.
1991 Nissan Skyline GTR, Pearl Black Metallic - a few goodies
Offline bnoon
  • Full Member
  • Thank You
  • -Given: 0
  • -Received: 5
  • Ecobooster
I just disconnected mine last night and took a trip around the block to make sure it didn't have any issues before I started buying intake parts.
Offline EcoBrick Bob
  • Elite Member
  • Naples, FL and Clear Lake, IA
  • Thank You
  • -Given: 62
  • -Received: 101
WHY?
"What difference does it make?"  (H. Clinton)  LOL :bangin:
Naples, FL & Clear Lake, IA
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
I just looked up an article on the BoV installation on your guys car.
So, now I'm looking at buying a SHO intake tube that goes from TB to IC and then have Paul make a tube that replaces the SHO/Flex back turbo to IC tube with no holes in it for BoV.
This way an aftermarket BoV can be added to the intake tract and the factory BoV can be removed entirely.
We're looking at a way to make a plug and play resistor to replace the factory BoV as well so no CEL
Hmm that part is AA5Z-6F073-B - $110... More research to do :)
« Last Edit: May 09, 2013, 10:39:30 AM by 4DRHTRD »
Offline bnoon
  • Full Member
  • Thank You
  • -Given: 0
  • -Received: 5
  • Ecobooster
WHY?
The reason I'm doing it is to make super shorty intakes, basically just filters on the turbos. I don't care about IAT, only boost temps. This will simplify and eliminate a lot of hardware real estate under the hood for when I go liquid to air intercooler.
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
WHY?
Keep me in the loop on this, I'm looking at doing that after I get fueling/turbos installed in a month or two.
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
Video
Offline bnoon
  • Full Member
  • Thank You
  • -Given: 0
  • -Received: 5
  • Ecobooster
WHY?
Sure will. Do you know the turbo's factory inlet diameter? Looks to be around or just under 2 inches but I can't tell for sure without disassembly.
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
I don't think even 2", I'll have my stock-upgraded turbos back soon I'll take a measurement. In discussing the factory IC, I think I can pick up another 30+HP just by going with a water to air IC, I've been considering installing the heat exchanger in place of the factory IC as there will be space there, just need to find a core that is sized appropriately for that.
I'm going to be putting my water resevior in the rear spare tire area, I'm going to have a custom nitrous tank/water resevior built for back there when I do the IC upgrade.
Offline bnoon
  • Full Member
  • Thank You
  • -Given: 0
  • -Received: 5
  • Ecobooster
Since I don't go full bore racing with mine, I won't even have a remote resevoir for mine. Just the largest h\e I can fit and a small overflow bottle for the pressure release lid.
  • Elite Member
  • Thank You
  • -Given: 62
  • -Received: 101
Don't quote me, but I think I remember Darreli saying the inlet is        1 1/2" as the Hennessey CAI system he bought a couple years ago didn't have a reducer/taper and just went from 2" to 1 1/2".
  • Elite Member
  • Thank You
  • -Given: 62
  • -Received: 101
With your nitrous system you might get that extra HP, but my MCT temps running 75% methanol went below outside temp, so not sure how much cooler one could go with liquid IC, unless the liquid would be at a temp much below ambient.  Guess one could cool it with A/C system..
  • Vendor
  • Elite Member
  • Phoenix
  • Thank You
  • -Given: 147
  • -Received: 1237
    • EcoPowerParts
Another video
  • Elite Member
  • Thank You
  • -Given: 62
  • -Received: 101
I would do this only if it will make "LOUD FART SOUNDS"... :biggrin:
* Recent Topics
Re: New Moderator
by sm105k | Today at 02:31:56 PM
Congrats E!  I have not been active much but Great to see others ...
Re: New member Omaha, Nebraska
by FearlessAZ | Today at 04:50:17 AM
Welcome to the forum!Love that color. Was that a factory color or some...
Re: Finally bought an XDI35 HPFP
by bamsho | July 03, 2020, 10:42:00 PM
Here is a comparison slips.  There is an 20 degree ambient temp d...
Re: Ride of The Month - July 2020!!
by Dannymack | July 03, 2020, 06:29:59 PM
Going for round #2.2013 MKSAJP E30Godspeed SpringsBunch of Aesthetic M...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Back to top
