Here is one installed...I will try and grab one from the side later but honestly since I just put it in the car I'm not terribly motivated to pull it out for a pic just yet. Are you interested in seeing how it seals or more about the second air inlet?
I can tell you that it is difficult to seal off on the drivers side as that bend is pretty sudden but the cover does have a lot of give to it so it bends more than you think it might. The bolts that are on there are where they are because that was where I wanted it to bend to get the best seal. The hood also seems to sandwich everything pretty tight now as well, especially upfront, so that should help.
I should also note that I am not using the original weather stripping that came with it but a "bulb" style 0-- that has more sealing surface which also helps.
