July 09, 2020, 11:31:49 PM
Author Topic: What have you done to your Ecoboosted vehicle today?  (Read 1926892 times)
Offline bamsho
  • south williamsport, pa
  • -Given: 186
  • -Received: 494
« Reply #7470 on: May 16, 2020, 05:59:08 PM »
Blah Blah Blah
Offline bpd1151
  • Forum Supporters
  • SHOcago S/W 'Burbs
  • -Given: 2431
  • -Received: 2485
  • SHOGAZM
« Reply #7471 on: May 16, 2020, 06:03:39 PM »
Blah Blah Blah
Hahaha. I believe a song was made after that phrase. Yup. Sure was. Here you go buddy. Just for you.....
World's Highest AWHP SHO (Aug. 2014 - June 2016) & World's Fastest Ecoboost SHO (Nov. 2015 to July 2019) Details Here: http://www.dragtimes.com/Ford-Taurus-Timeslip-27985.html
Offline StealBlueSHO
  • Administrator
  • -Given: 2651
  • -Received: 2708
  • I poke at BPD1151
« Reply #7472 on: May 16, 2020, 07:45:41 PM »
Blah Blah Blah
Blah blah blah all you want, you are just about there too!
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Offline Chris_Flex
  • Full Member
  • Lancaster,PA
  • -Given: 40
  • -Received: 92
« Reply #7473 on: May 17, 2020, 06:57:21 PM »
Replaced my AC condenser today was really surprised to see it also has a trans cooler with it on my flex are the SHO like that also?
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
Offline SuperPete
  • Full Member
  • Pennsylvania
  • -Given: 12
  • -Received: 104
  • SHO Kind of guy
« Reply #7474 on: May 23, 2020, 02:03:10 PM »
correct, SHO also has trans cooler inside of the condenser, just like yours.
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
Offline MKS Tom
  • Super Moderator
  • Full Member
  • PA
  • -Given: 66
  • -Received: 102
  • Weirdo
« Reply #7475 on: May 24, 2020, 03:45:06 PM »
Air filter for the MKT and new battery for the MKS.  Both cars are filthy.  lol  Started working on my Subaru SVX as well again today too.
Offline MKS Tom
  • Super Moderator
  • Full Member
  • PA
  • -Given: 66
  • -Received: 102
  • Weirdo
« Reply #7476 on: May 24, 2020, 03:45:53 PM »
Gross.
  • Administrator
  • -Given: 2651
  • -Received: 2708
  • I poke at BPD1151
« Reply #7477 on: May 24, 2020, 05:44:23 PM »
Just a quick clean with my favorite detailing product!
Offline bamsho
  • -Given: 186
  • -Received: 494
« Reply #7478 on: May 29, 2020, 01:31:59 PM »
Well I said bye bye to the noisemaker.  Bought an Explorer Sport pipe, guess the MKS is on national back order.  Had to do some modification, and bought Vibrant silicone tube to go from pipe end to throttle body.  Also relocated the meth nozzle too.
  • Administrator
  • -Given: 2651
  • -Received: 2708
  • I poke at BPD1151
« Reply #7479 on: May 29, 2020, 04:20:55 PM »
how much did that end up costing you?
Offline MKS Tom
  • Super Moderator
  • Full Member
  • PA
  • -Given: 66
  • -Received: 102
  • Weirdo
« Reply #7480 on: June 02, 2020, 10:09:59 AM »
Dropped mine off at the dealer.  Was having shifting issues as soon as I left the driveway.  Was able to get it back in the driveway.  Tried it again in the morning with similar results.  I was able to drive it to the dealer that is about 2 miles away and it seemed better but I didn't push it at all.  I have a warranty and I have been stock since February.  I expect it to be covered.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
« Reply #7481 on: June 02, 2020, 10:58:23 AM »
Good luck.  Hope it is not the dreaded direct clutch issue, just a range sensor :)
Offline MKS Tom
  • Super Moderator
  • Full Member
  • PA
  • -Given: 66
  • -Received: 102
  • Weirdo
« Reply #7482 on: June 02, 2020, 11:13:11 AM »
With having a warranty I hope it is the trans and the torque converter.  lol
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13013
  • -Received: 4215
« Reply #7483 on: June 02, 2020, 11:47:41 AM »
Lol i agree!
Offline mrhighcaliber
  • Full Member
  • -Given: 309
  • -Received: 153
« Reply #7484 on: June 05, 2020, 04:48:17 PM »
Got my block and crank back from Holbrook Racing engines. I drilled and tapped the outers main holes from a m9 to the m10 to accept the Livernois/ARP hardware for the 2018 blocks. I Also drilled the outer main cap holes and windage tray holes to accommodate bigger stud hardware. Had the mains align line honed, crank journals polished and both hot washed.
Sent from my PH-1 using Tapatalk
* Recent Topics
Re: Kill of the week
by ridered74 | Today at 10:22:09 PM
Second week in a row I had the pleasure of racing a mustang. This one ...
Re: '14 Explorer Sport greetings from Charlotte NC
by PDSHO | Today at 06:58:18 PM
Re: New member central pa
by PDSHO | Today at 06:54:59 PM
Re: New member Omaha, Nebraska
by PDSHO | Today at 06:52:20 PM
Greeting and welcome from another Nebraskan.I live between Omaha and F...
Re: Has anyone install custom Hood?
by 6500rpm | Today at 03:57:41 PM
I put the chin spoiler  on my 13, required a little profiling in ...
Official Instagram and Twitter Pages
by StealBlueSho | Today at 12:34:03 PM
Things have been crazy outside of the ecoboost world for me but I have...
by ridered74 | July 08, 2020, 11:10:23 PM
So I had Gearhead center cap overlays on my stock wheels... and missed...
by Dxlnt1 | July 08, 2020, 10:29:41 PM
That doggone BPD guy shattered my build tho lol.Sorry......Sent from ...
by StealBlueSho | July 08, 2020, 09:05:33 PM
https://uploads.tapatalk-cdn.com/20200708/36af6e707bd7f56f9890812e7098...
Re: Meth Switch and Relay lifespan?
by 76fomoco | July 08, 2020, 06:00:04 PM
if your not meth dependent I wouldn't worry about it. But for the...
Back to top
