July 03, 2020, 11:37:11 AM
Author Topic: What have you done to your Ecoboosted vehicle today?  (Read 1918502 times)
Offline Jordan
  • Elite Member
  • Columbia, Mo
  • Thank You
  • -Given: 224
  • -Received: 643
  • I'm the captain of this SHIP
« Reply #7440 on: April 18, 2020, 03:58:55 PM »
Got my kirkey seat installed today.
Offline Chris_Flex
  • Full Member
  • Lancaster,PA
  • Thank You
  • -Given: 40
  • -Received: 92
  • Ecobooster
« Reply #7441 on: May 02, 2020, 11:51:31 AM »
Itching to get to the drag strip!
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
Offline StealBlueSHO
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2631
  • -Received: 2690
  • I poke at BPD1151
« Reply #7442 on: May 02, 2020, 03:45:28 PM »
New shoes! Enkei 20x8.5 +40mm offset with 255/45/20 Continental Extreme Contact DWS 06.
Got the 4 wheels and Blizzak tires for $350, got the Contiís  installed for $900.
Had them mount and balance the Blizzaks onto the stock flower wheels for future winter driving.
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2631
  • -Received: 2690
  • I poke at BPD1151
« Reply #7443 on: May 02, 2020, 03:46:14 PM »
Offline Kanajana
  • Forum Supporters
  • Newbie
  • NEPA
  • Thank You
  • -Given: 7
  • -Received: 2
  • Ecobooster
« Reply #7444 on: May 02, 2020, 09:54:18 PM »
StealBlueSHO,
Very clean, looks great. Gravity cast? Slightly lighter than OEM?
2014 Ford Flex Limited EcoBoost
LMS 93 v17 + 3bar MAP + 160į t-stat // MSD Coils // H&R + Air Lift 1000 Springs // Centric Cryo rotors + Hawk LTS pads + G-Stop SS lines // mmstar RGB Door sills // Bright TRAX Puddle Lamps
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2631
  • -Received: 2690
  • I poke at BPD1151
« Reply #7445 on: May 02, 2020, 10:17:42 PM »
StealBlueSHO,
OEM is 32lbs from my understanding... these are 26.85lbs plus the tires are lighter... it equates to 8.15lbs per corns of rotational weight reduction.
Enkei Lusso... not sure what cast...
« Last Edit: May 03, 2020, 07:47:39 AM by StealBlueSHO »
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 929
  • -Received: 1090
  • Thee Forum Cowboy
« Reply #7446 on: May 03, 2020, 11:11:22 AM »
StealBlueSHO,
I like them.  With the un-sprung weight reduction you will feel a difference turning into corners and really getting out of corners.  With the wider combo you will also see better braking along with better launching capabilites.  Rims and tire combos are overlooked on most platforms because of the staggering price tags...
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter | Power Stop Brakes | Continental DWS06 Extreme Contact Rubber |
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2631
  • -Received: 2690
  • I poke at BPD1151
« Reply #7447 on: May 03, 2020, 11:19:14 AM »
StealBlueSHO,
100%... upgraded tires alone are usually one of the first modifications you should do. I was just keeping the stock look, decided wheels/tires are a better investment than a new Mustang... just to shake it up.
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 929
  • -Received: 1090
  • Thee Forum Cowboy
« Reply #7448 on: May 03, 2020, 03:00:32 PM »
StealBlueSHO,
I get that 100%.  There was a time I hated opening the garage and seeing my SHO.  I grew to absolutely HATE the chrome and really disliked the flower wheels.  When I paint matched the trim and threw on the Curvas on, I completely feel back in love with my her.  Now it is a treat to open the garage and see her.
Offline Slow15SHO
  • Jr. Member
  • Pittsburgh, PA
  • Thank You
  • -Given: 1
  • -Received: 14
  • Ecobooster
« Reply #7449 on: May 03, 2020, 07:26:11 PM »
Finally got the xdi-35 installed. Now it’s just waiting on the local tracks to open up to try and put this boat deep in the 11’s
« Last Edit: May 03, 2020, 07:44:52 PM by Slow15SHO »
2015 SHO PP
Tuned by Ortiz, 3 Bar, AFE Intake, 170 T-Stat, SP-542 Plugs
12.69 on 93
12.32 on E30
Offline ridered74
  • RotM Winner
  • Full Member
  • Thank You
  • -Given: 119
  • -Received: 159
« Reply #7450 on: May 03, 2020, 11:27:53 PM »
Finally got the xdi-35 installed. Now itís just waiting on the local tracks to open up to try and put this boat deep in the 11ís
What part of the burgh? I grew up a little south east.
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler and upgraded trans mounts.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
Offline Slow15SHO
  • Jr. Member
  • Pittsburgh, PA
  • Thank You
  • -Given: 1
  • -Received: 14
  • Ecobooster
« Reply #7451 on: May 04, 2020, 12:31:08 AM »
Just a bit north in the Cranberry area
2015 SHO PP
12.69 on 93
12.32 on E30
Offline wraitherx
  • Full Member
  • Hampton Roads
  • Thank You
  • -Given: 7
  • -Received: 57
  • Ecobooster
« Reply #7452 on: May 04, 2020, 03:56:29 PM »
2014 SHO PP
1999 SVT Cobra Built
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Elite Member
  • Arizona
  • Thank You
  • -Given: 929
  • -Received: 1090
  • Thee Forum Cowboy
« Reply #7453 on: May 04, 2020, 04:40:14 PM »
That would look sharper....with paint matched trim.....
I like it.
  • Administrator
  • Elite Member
  • Thank You
  • -Given: 2631
  • -Received: 2690
  • I poke at BPD1151
« Reply #7454 on: May 06, 2020, 04:31:47 PM »
Just a little fun!
* Recent Topics
Re: New member Omaha, Nebraska
by BigGrey150 | July 02, 2020, 08:15:35 PM
I actually live in bellevue on the north east side of the base. I just...
Forum Stickers
by StealBlueSho | July 02, 2020, 01:47:07 PM
EBPF Family..Anyone have any recommendations on who to go through for ...
Re: Ride of The Month - July 2020!!
by WinPlaceSHO | July 02, 2020, 01:34:42 PM
I'll bite... it's a good ole fashioned SHO down, mine is the...
Re: B1086- Air Distribution Damper Motor - Panel/floor/defrost not working
by Gjkrisa | July 02, 2020, 01:19:45 PM
New panel worked think I cracked part of the new facia trying to take ...
Re: DannyMack 13 MKS "Old Man" Build and Maintenance Thread
by Dannymack | July 02, 2020, 01:17:24 PM
Quick update. Been enjoying the car in its current form for a couple m...
Re: Help! Removal of Rear Turbo
by 802SHO | July 02, 2020, 12:18:51 PM
Thanks to you guys for all the tips. I wasn't sure about the knuc...
Re: 2015 Ford Explorer Sport - AC Compressor Not Starting
by lotusnotes | July 02, 2020, 12:07:40 PM
So I figured this out - whoever mounted the light bar on this truck be...
Re: TASCA=Fail....
by nickstewartroc | July 02, 2020, 12:01:03 PM
I usually use tasca to look up part numbers.  And then go to my l...
Re: So Lets start some banter
by nickstewartroc | July 02, 2020, 11:59:05 AM
+1 on the FiST. Love mine, going on 5 years now with it, upgraded turb...
Re: 2020 June RoTM Winner!!!
by StealBlueSho | July 02, 2020, 10:34:19 AM
Sweet!! I'll PM you my address so you can send me the trophy and ...
Back to top
